Results 11 to 20 of 31
Thread: Reverse Camera Install - help!
    Jun 2007
    South West WA
    I also need to tap into the wires for my aftermarket camera. With the CANBUS, am I right in thinking a old school 12v test light won't show me which of the two wires to the reverse light (grey and then a brown with white line) in our Jetta is positive ? - no success to date ?
    Anyone help ?
    MY18 Skoda Kodiaq TSI with Luxury and Tech packs.
    Mar 2009
    UMG Brisbane
    Grey is typically fog, but that is aus wiring codes so may be different (we all have a fog on one side, and a reverse on the other...)
    Al..
    2013 MY13.5 Passat V6 Highline Wagon. Watch this space
    GONE:2017 MY18 Skoda RS169 Wagon w/ Tech & Lux, 2007 VW MKV Golf GTi
    Jul 2005
    Newcastle, NSW
    Quote Originally Posted by iamthestig View Post
    Anyone help ?
    Buy a multimeter.
    Dec 2009
    Kew, VIC
    Should be simple — unplug the 2 wires and the one that lights your test lamp is +.
    If the wires don't unplug, remove the globe instead.
    Mar 2009
    UMG Brisbane
    Anyone help ?
    Doh! The test light will still work at the light end. If you have a multimeter that is a dead cert way to tell...
    "This honestly, it is Winnie the Pooh with road rage". Clarkson on the new AMG C63 Black
    Jul 2010
    Robina Gold Coast
    Quote Originally Posted by minircc View Post
    Hi all,
    I installed a reverse camera to my 2007 Jetta today using the following simple guide.
    http://www.hemanavigator.com.au/Port...ide_v_3web.pdf
    That is, video cable wired to front of car and camera powered through tapping the reverse light.
    It works when i tested it without the engine running (ie. key in ignition one turn). I put it in reverse and the pretty picture shows on screen.
    PROBLEM: However the camera does not work when i have the engine running and i put it in reverse. failed..
    It is because VW's have some sort of power regulator to the reverse light stopping enough power going to the camera when the engine is running?? I can't think of anything else.
    I have wired it this way for many other cars and it works fine.
    fyi, i have an ebay GPS rns510 look-a-like head unit. (works fine)
    Thats the same reverse camera and monitor type ive used in my golf ,except ive wired it to the rear cigarette lighter plug it stays on all the time ,i tried to connect it to the reverse but it would not work ,i was going to install a relay but just havn't bothered as it doesn't doesnt annoy me being on all the time .
    Jun 2007
    South West WA
    Quote Originally Posted by 99_FGT View Post
    That is the problem - my old tech test light does not light up even when plugged in the reverse light terminals !
    As the Jetta has both the number plate light (for camera mount) and the reverse light in the boot lid, I want to find a feed there instead of running a feed wire from somewhere else (like the 12v in the boot).
    Dec 2009
    Kew, VIC
    If you remove the reverse light bulb, connect your test light (make sure it has a good earth) close the boot lid and activate the reverse light (ignition on, engage reverse, step on the brake,) your test light will light up if connected to +12V.
    If it doesn't, you have it on the wrong terminal.
    Good luck finding permanent +12V in the boot lid — I don't think there is one.
    Jun 2012
    North Ryde, NSW
    I installed a camera today and have the same issue where it works when the engine isn't running, a perfect picture is displayed. But when the engine is runnning the picture flickers, changes colors and unwatchable.
    I tested with a multimeter and when the engine isn't running but in the accessories position the multimeter is measuring 15.6, when the engine is running the multimeter is measuring close to 17. Seems like the camera doesn't like the extra volt or so. The power specs for the camera is 8-16.
    Is there any way I can fix this? Do I need a voltage regulator for the camera?
    Jun 2012
    North Ryde, NSW
    So I tried one of these today MC78T12 12V 3A Voltage Regulator - Jaycar Electronics
    I hope that this would fix my issue, no luck though. Any ideas?
