Originally Posted by
Idle
I've only been involved with Golf camera setups and didn't know there was a difference between the wagon and Golf latches — sorry.
OEM connections are usually polarised and pretty foolproof, but I'd still go over the connections around the camera (check polarity as well as continuity) carefully before declaring it faulty, with particular attention to possible voltage drop and grounding.
Also, if you can, check the video cable connections in case there's a break/bad contact somewhere in one of the lines or on a pin.
Can't remember the number of times I've had to distort a connector to ensure contact.
Beyond that, I think I'm as flummoxed as you are.
