Refer to post 15 & 16 of this thread, to see the difference on the screen!
Do you remember whether you had the green & gold lines that moved on the screen as you turned the steering wheel?
MY11 Tiguan 147TSI (SOLD)
The dealer where I bought the car from disabled the RVC because it was faulty (not going back to them), so I have never seen it actually working, a forum member activated it a few weeks ago and showed me the camera pop out when we out it in reverse gear which never happened before so I never knew there was a RVC in it. The screen simply displayed OPS and no video area prior to activating the camera.
Took the car in at Denlo, they said the camera itself is faulty. They have apparently ordered a new one from Germany because the "$1100 part is to expensive to keep in the spare parts room".
PS. they disabled the camera before handing over the car, it was an ex-demo and i never knew it had an RVC..
In that case, only a VCDS scan and looking at the part no. will confirm whether you have the extra control module or not.
In your situation, most probably have to take their word for it. But doesn't hurt to get them to write or read it out to you to check back later.
It's being repaired through warranty. Do you know if the B7 Passats with factory fitted RVC are meant to have the dynamic line control module?
It's a Passat 125TDi Highline
Yeah, mine a fully optioned sedan..
MY11 B7 Passat 125TDi
Pearl Mocca Anthracite | Electric and Heated Leather | Electric Folding Mirrors | Sunroof | Bi-Xenon and DRL Package | Adaptive Lighting Package | Park Assist 2 | Lane Assist | RNS510 RVC | R36 Pedals | De-Badged | VCDS Mods
MY11 B7 Passat 125TDi Highline
Pearl Mocca Anthracite | Electric and Heated Leather | Folding Mirrors | Sunroof | Adaptive Lighting Package | Footwell Lighting | Park Assist 2 | Lane Assist | RNS510 | R36 Pedals | Scirocco MFSW | Front Lip | 20" Suzuka Wheels | H&R Springs | De-Badged | VCDS Mods | Alpine Mono and 8" Subwoofer
The module should be above the rear dr. side wheel arch and is visible if you remove the little door in the trim and look up, you should see the box approx. 150mm x 150mm there.
There is no access door for anything behind the boot lining. I have uploaded pics at the links below, not sure if they work though.
I don't really want to remove the whole boot lining because it is really tightly sealed behind the rubber seals
http://imageshack.us/a/img825/1609/photo2vir.jpg
http://imageshack.us/a/img713/759/photo1wpu.jpg
