Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: Reverse Cam on RCD-510 - brightness/quality issues?
  1. #21
    Mar 2009
    UMG Brisbane
    I'll weigh into this, bright sunlight - no issues with flaring, VW camera to RCD510.
    And a couple of lower light (same time) shots.
    Will try and get some night ones too, but my camera is sharp and adaptable to most light conditions.
    2013 MY13.5 Passat V6 Highline Wagon. Watch this space
    GONE:2017 MY18 Skoda RS169 Wagon w/ Tech & Lux, 2007 VW MKV Golf GTi
  2. #22
    Adelaide hills, SA
    It could be too much of the sunlight, where the camera is facing up and you get part of the picture with too much light the rest of the picture will look dark as the camera auto adjust its aperture. Looks OK to me.
    What's the image like at night when there are just the reverse ligh and the street lights?
  3. #23
    Pacific Paradise QLD
    Quote Originally Posted by 99_FGT View Post
    What I was referring to is when the camera is in DIRECT Sunlight as in the sun is shining right at it.
    All those shots have the camera shaded from the sun
    Take some with the sun directly behind the car and see what you get.
  4. #24
    Jul 2010
    FWIW, how the hell do you get direct sunlight into the camera?
    Isn't it pointing down at the ground?
    Anyhow, perhaps a faulty camera as there's really no settings that you can play with.
    MY11 Tiguan 147TSI (SOLD)
  5. #25
    Quote Originally Posted by aussietig View Post
    Just park it with the sun directly behind it and see what happens.
    I know the camera points down but reflected light off the ground can upset some
  6. #26
    Mar 2009
    UMG Brisbane
    Re: Reverse Cam on RCD-510 - brightness/quality issues?
    If you look at the first pic, that is in full sun, I actually had to shield the screen with my body to even take the pic, so you are right when you say you can't see the screen. That is as bad as mine gets, as the camera does point down...
  7. #27
    Yes I understand that but the camera is not in the direct sun and that is what causes flaring.
    Of course if the sun is on the screen it will be hard to read but thats not what Im talking about .
    Park the car with the sun shining directly on the rear and then take a picture of whats on the screen The camera I had was fine till it was like that and then the picture just went into a big patch of whiteness. Nothing to do with the light in the car. Was the camera overexposing due to its design limitations.
  8. #28
    Mar 2009
    UMG Brisbane
    right back at you
    The sun is shining directly on the back of the car in that photo, is like that every morning when I go to work.
    The camera, a badge pop out type one, is not in the sun, the sun would need to be lower than horizontal for it to be shining on the lens because of the design of the camera. If it is, can someone call a tow truck please?
    Other than that, I've got nothing
  9. #29
    Adelaide hills, SA
    I think that anyone with the RVC will find that in certain conditions the RVC image on the screen is similar to yours or otherwise imperfect. What I'm saying is, that if the RVC works well in other situations, then there is nothing wrong with it. The camera sensor, optics and the software would be inferior to even the low end pocket cameras, so don't expect the image like from DSLR.
    The above is without seeing the image and conditions in the real time and being there, so trying another RVC could reveal that yours could be faulty too. The easiest would be to try the similar car with the same RVC at your place. Any friends that have the same car living close to you?
