Results 11 to 20 of 29
Thread: Reverse Cam on RCD-510 - brightness/quality issues?
    Mackay QLD
    Quote Originally Posted by Domz View Post
    Hi Guys
    I have had a RVC retro-fitted on my RCD-510, and find that the quality is quite low compared to other cars.
    Also the brightness is very low, is not light-sensitive, and the adjustments on the screen do not function.
    The fitter claims that this is due to the unit not being the GPS version, the resolution will be low and you cannot control the brightness.
    Does anyone else have a RVC on there RCD? and how is it?
    Also I do not have the guiding lines, just the image. Can this be added in aftermarket?
    Can you upload an image of the RVC in operation? There are 2 types of RVC's a basic unit with fixed yellow lines for about $250 or an advanced one with yellow and green - red guiding lines for about double the price as it includes a module that talks to the steering wheel angle sensor et al to guide the car. The brightness contrast can be controlled on the latter unit only via an Rns510 navi but not sure if you can do it on the RCD 510
    I have installed 2 basic units in my old and new Tiguans and neither of them have had poor images. However at night they are not great and are limited to no more than 2 to 3 meters where there is some street lights. I have not checked where there is only the car reverse lamps to light up the environ.
    MY 21 T Cross 85TSI Life| Makena Turquoise | Driver Assist Package |
    Mods: VCDS tweaks |
    Jan 2013
    Quote Originally Posted by Bambazonke View Post
    I'll take some pictures and upload them in the weekend. Cheers.
    photos added:
    Jan 2013
    photos upload again
    Tiguan Pacific MY12
    Jan 2013
    The pictures were taken yesterday when it's cloudy. The image is worse when it's bright on a sunny day, and you'll hardly see the screen.
    The first photo was taken from the driver seat. The second one is perpendicular to the screen.
    Tiguan Pacific MY12
    Mackay QLD
    Looks like the basic OEM RVC has been installed. From the pics above I doubt if a rns510 that has a higher res screen and brightness contrast controls will give a substantially better pic
    Mods: VCDS tweaks |
    Adelaide hills, SA
    There is no difference in the picture quality from RVC between RCD510 and the RNS510, since the camera sensor is very small.
    Dec 2012
    *deleted comment
    Pacific Paradise QLD
    In bright sunlight does the picture flare out so details cant be seen.
    Had a camera on a Caravan that did that Was one that was optimised for night vision and flared out in daylight.
    Wasnt a high quality one at all.
    Does you camera have infra red LED's around the lens
    Apr 2010
    I bright sunlight you can't really see the HU screen anyway
    I realise that but what I meant was that when the camera is in direct sunlight a cheap one will overexpose and the picture flares and you cant see anything.
    Doesnt matter what the screen orientation is, its what the camera is seeing.
    You could be backing out of a garage and the tail is out in the sun and it will do it
