Results 1 to 8 of 8
Thread: Reverse Badge Camera for MKV Gti
    Oct 2009
    Hills, NSW
    Hi All,
    I am looking at buying the below from Ebay.
    http://www.ebay.com.au/itm/180968910...t_15537wt_1163
    Does anyone know what sort of money this will cost to install?
    Anyone on the forum have the expertise to help out?
    thanks for looking and your suggestions.
    MY07 Golf GTi
    Leather | Sunroof | Bi-Xenon | Reverse Sensors | Bolle Tints | RNS 510 | MDI
    Jun 2011
    Quote Originally Posted by DiZzY View Post
    Hi All,
    That link is not working, but I believe it would be around $350. I don't think anyone other than a professional installer would be willing to do this as it is quite complex. Feel free to give it a go though, maybe you're lucky enough to have a guru near you, but it'll still cost you more than just a beer.
    Mine was around $150 to install it through Audi Upgrades. They'll only install it if you buy it through them though.
    Sent from my GTI using Tapatalk.
    Jun 2011
    Quote Originally Posted by Deadpool View Post
    For the badge RVC? They said it was $350 here:
    RNS 510 Navigations available from Aussie dealer - www.JKU.com.au - free postage
    AFAIK also their workshops are independent anyway i.e. not part of Audi Upgrades, just affiliated installers. No reason why they won't install it - maybe they just have cheaper install prices if you buy through Audi Upgrades.
    Not what I was quoted, but then again I did couple it with a Bluetooth install so I got it cheaper. Don't remember being anywhere near $350.
    Pacific Paradise QLD
    There are two versions of these cameras on Ebay One has an RCA connection for the video feed and is not the same as the OEM one which has a different connector that marries up to the 26 pin connector on the headunit.
    The RCA version is $285 on EBAY atm the OEM version is a lot more.
    This is the OEM VW Rear Badge Camera Emblem Badge Camera FOR RNS310 315 510 810 850 RCD510 550 | eBay
    This is the RCA eBay Australia: Buy new & used fashion, electronics & home d�r
    Note the yellow plug in the parts pic
    This is the GOOD headunit Genuine VW RCD 510 6 CDS Head Unit Stereo FOR Golf Jetta EOS Passat Tiguan Polo | eBay
    One gives you the lines in the screen the other doesnt apparently
    It depends what headunit you are connecting it to which you should buy.
    I looked at fitting one to our Polo but even doing it myself , after buying an RCD510 for about $350+ and the camera for $350+, an adapter for $50? and the time to do it I was looking at $800 approx so thought it not worth the trouble
    Adelaide hills, SA
    Quote Originally Posted by DkN View Post
    I charge the same regardless where you bought it from.
    But, it's much easier to find the solution if for instance, you've bought the LED tail lights for the Golf6 and one of the light has a problem or the wiring adaptor doesn't fit or something. Then, it's only one phonecall to Audi Upgrades and we would work something out. Where, if you've bought from the ebay, then you're on your own to sort it out with the ebay seller, paying for the time lost and who knows what else?
    If you buy of the ebay, then you're responsible for the quality of the parts, not the installer, and it can mean the delay in the installation and additional charges. It happened few times now that, the wiring that customer brought to me with the BT kit or RVC was damaged or incomplete or even the wrong BT kit for the car.
    Oct 2009
    Hills, NSW
    Many thanks for the replies guys.
    Thank you
    MY07 Golf GTi
