Results 1 to 10 of 15
Thread: Retrofit of Bluetooth & MDI kit to Passat R36
    Aug 2011
    Woah slow down guys. An important thing to note with the BT systems is whether they're compatible with your MFD screens. Is the screen in between you tacho Red or White? Because the 9W7 is only compatible with White screens.
    If you upgrade the firmware on your unit (which there is a bunch of info in the stickies in this forum) you shouldn't have issues with compatibility on the RNS side of things
    Edit 9W7 will show up on the RNS510 screen but won't show on the Tacho, you will need VCDS to add Telephone to the CAN Gateway
    Jul 2012
    Melbourne, Victoria
    Thanks readerr0r
    Quote Originally Posted by readerr0r View Post
    MFD in my 2008 R36 is Red .
    Is there a BT module that is compatible with the Red MFD? The Mobridge BT module I posted earlier (CAN Bluetooth | mObridge) states: "Full integration into Multi-Function Display and Touch-Screen Radio"
    Don't have access to VCDS so am hoping someone will chime in with an offer of help for the install (plenty of Beer involved)
    @Red Diablo: Will keep you posted on my progress.
    Thanks again for the help lads.
    Aug 2011
    Well it's a bit of a tricky one. The lastest white only units do A2DP audio streaming with control and work fine through a RCD/RNS 510 but won't show up on your tacho. While the much older red units will work but are a bit tricky to find, won't have A2DP but will work on your tacho. So I guess you need to decide whats more useful to you.
    Carsystems also sell the red friendly unit
    VW Bluetooth 1Z0035729B - Upgrade Kit -
    Jul 2012
    Melbourne, Victoria
    Hi all,
    Thought I'd post back with an update.
    Carsystems Bluetooth module installed with a great help from buckets - thanks mate
    BT module works perfectly with the exception of not appearing in the MFD (as advised by readerr0r) which is no biggy as all details appear in the RNS.
    Carsystems MFD kit VW MEDIA-IN + iPod iPhone adapter - Kit for cars with AUX-IN - Retrofit -5N0035342E works with a USB thumb drive, but doesn't recognize iPod/iPhone and displayed "MEDIA-IN not functional" on the RNS. Upgrading the RNS510 firmware to 3970 didn't make any difference, however the error on the RNS changed to the even more helpful "Device without Function"
    A quick search of the forums revealed this post where gjws was having the same error: http://www.vwwatercooled.org.au/foru...ror-63103.html
    Just need to get my hands on a correct MDI cable to test and be sure....
    Mar 2009
    Hi bts,
    Good news on the install.
    My R36 is December 08 build with a white MFD and the RNS510 is a B-Series.
    I'm particularly interested on the installation process and I noticed on the Carsystems website that they provide "Step by Step Installation manual". How usefull was it?
    Jul 2012
    Melbourne, Victoria
    Hi mate,
    Installation overall wasn't hard and was pretty much just plug & play.
    Install of the BT unit is supposed to be under the seat but not worth the trouble IMO as there's enough room behind the RNS which is where we opted to install mine (just remove the BT unit from the foam).
    Most difficult part (if you can call it that) was ensuring there was enough clearance in behind the RNS once the BT and cables were installed (I had the cable from the MDI kit in there as well).
    Can't say much about the installation manual as I never received one for the BT module lol Got one with the MDI kit which was used at the end for the VCDS coding.
    Feel free to PM if you need more details .
    Jul 2012
    Melbourne, Victoria
    One thing that is slightly annoying is the PTT button is set to mute and the phone button does nothing (even when receving or trying to end a call). Assume I need to recode the MFSW controis, as per the following coding on Ross-Tech:
    VW Golf (1K) Steering Wheel - Ross-Tech Wiki
    Any pointers on what needs to be changed?
    Apr 2010
