Apparently I'm not as good as I used to be with google. I think that this will do the trick: https://www.aliexpress.com/item/High...737938580.html
Hey guys,
I just finished replacing my RNS 510 in my VW Golf with a RCD 330+ and I'm loving it! It is so much more responsive than RNS 510 and it is capable of mirrorlinkIt's also plug and play, which is awesome
But I'm having an issue connecting the OEM reverse camera. The seller provided an adapter for the RCD 330 to RGB but I've been trying to find an adapter for the rectangular SCART looking connector to a male RGB connector, but no hope so far. Does anyone know what the connector is called/where I can find an adapter for it?
Thanks,
ps. Hit me up if you have any questions about the RCD330+. I've done my fair share of research and I'll help you where I can.
Yep that's what you'll need.
If the rcd330g plus had android auto it would be a really compelling option.
It seems a major oversight but it's for the Chinese market so I guess they don't use it there?
Is this a CarPlay compatible unit and is it a straight swap for an RNS-510? What part does OEM Bluetooth (9w7) play, if any?
Daily: 2010 Tiguan TDI | Candy White | Manual | 4MOTION | New York Wheels | Comfort Pack | Tinted Windows | Discover Media | MkVI MFSW | Mk7 Climatronic | RVC | Fog Lights | ECB Nudge Bar | Hella 160 Driving Lights | Rola RBXL135 Cross Bars | To Do: Colour MFD
Toy: 2008 GTI Pirelli | Sunflower Yellow | 3 Door | DSG | Pirelli Wheels | RNS-510 | 9W7 Bluetooth | RVC | Rear Sensors | Fog Lights | To Do: Mk7 Climatronics, MkVI MFSW, Colour MFD
Yes it does support CarPlay. Bluetooth is integrated in the unit, no external module is required (or works with it)
You can find the CarPlay compatible one here: https://www.aliexpress.com/item/Carp...791999739.html
So the story is that there are 2 types of RCD330 plus, one is made by 'noname' and the other is made by 'desay'. The noname one is compatible with CarPlay and is running a linux OS whereas the desay one is running windows CE. But saying that, not all noname ones have CarPlay, you need to solder on extra ram and then flash it. I'm assuming that the seller from the link above has already done this. Also, the currently CarPlay firmware is buggy, it is only a beta version.
... I only found this out AFTER I purchased the desay one, doesn't make much of a difference as I've got an android phone. Still hurts a little bit inside.
In regards to your question about it being a straight swap, it is! And there is no need for a separate bluetooth module. It is all included in the RCD330 plus package. Thats why I swapped out my RNS510, I wanted bluetooth and its actually cheaper for me to buy this than the 9w7.
The general consensus seems to be that the noname verion will receive firmware updates sooner than the desay ones. So take that into account if you're thinking of purchasing one. But they are more expensive.
