Page 51 of 55 FirstFirst ... 414950515253 ... LastLast
Results 501 to 510 of 548
Thread: Replacing RNS 510 with RCD 330+
  1. #501
    Dec 2006
    Kilsyth, VIC
    Quote Originally Posted by richmurphy View Post
    I've isolated the issue to the reverse signal. I found it gets 0.7v momentarily after moving to ACC. Id guess this is checking for a blown bulb but it's enough to activate the camera mechanism. Also unplugged the camera and confirmed the 0.7v spike is still present.
    Might be more than 0.7v if it's a really quick spike but that's all my multimeter registers. Either way, seems like normal behaviour from the car.
    Yep, that's the bulb check pulse. You see cars with LED reverse lights often flash because of that too.
  2. #502
    Dec 2012
    Quote Originally Posted by The_Hawk View Post
    Thanks. Guessing it's more that 0.7V if it flashes the LEDs. It's sitting at 0.5V anyway so I'd be surprised if the extra 0.2v is enough to trigger the badge. My multimeter probably isn't quick enough to register the true voltage.
  3. #503
    Albany, WA
    @Richmurphy, do you want to put in a low resistance to see if the small voltage fluctuations get ignored?
    Finally finished install. Android Auto and Rearview camera with moving lines. Happy day1
    Happy days.Replacing RNS 510 with RCD 330+-img_20200507_144702-jpgReplacing RNS 510 with RCD 330+-screenshot_20200507-182016-jpg
  4. #504
    Albany, WA
    Hmm just realised car image not showing up, will go through VCDS
  5. #505
    Albany, WA
    https://www.autoevolution.com/news/g...es-143427.html
    Incase Android Auto not working appropriately for anyone.
  6. #506
    Dec 2012
    [QUOTE=sn809;1313558]@Richmurphy, do you want to put in a low resistance to see if the small voltage fluctuations get ignored?
    I tried using a 330 ohm resistor I had lying around. The camera didn't open. Unfortunately it didn't open when I engaged reverse either!
    Obviously 330 ohm is too high - might check the current draw and work backwards. I'm actually surprised the bulb check didn't fail so I might look closer at that too.
  7. #507
    Albany, WA
    There is also a cold diagnosis back up light option in vcds, you could try disabling that on vcds at your own risk though
  8. #508
    Aug 2012
    perth
    I'm sure this question has been asked befoer, but I can't find any info. I've just bought an RCD340, installed it and it's great. The OEM rear camera isn't working as I'm not sure how to plug it in. Is this going to require a new aftermarket camera and an auto-electrician to wire it in or can I do it myself and can I use the OEM camer? thanks
  9. #509
    Albany, WA
    Yes, there should be a yellow connector with a blue pin connector at the end. The pin connector goes under the Speaker jack and the yellow one should link up with your OEM camera.
  10. #510
    Aug 2012
    perth
    Quote Originally Posted by sn809 View Post
    Sorry not sure what you mean. The OEM camera doesn't have an RCA plug, actually I have no idea what plug or cable belongs to the OEM camera. Are you saying I should buy a new camera and ditch the old one?
    New cable that came with RCD 340 that connects 340 to the RCA port on the reverse camera except my OEM camera does have RCA
    Replacing RNS 510 with RCD 330+-`-jpg
    Main RCD 340 Port
    Replacing RNS 510 with RCD 330+-3-jpg
    Remaining plugs from RNS 315 that won't plug into RCD 340G, not sure what they are, large 24(?) pin black plug and blue plug
    Replacing RNS 510 with RCD 330+-4-jpg
    Old RNS 315 ports
    Replacing RNS 510 with RCD 330+-5-jpg
    Attached Thumbnails Attached Thumbnails Replacing RNS 510 with RCD 330+-2-jpg
