Hello everyone
I have a 2006 Škoda Octavia II (the Golf MK5's Škoda cousin)
I have a Skoda columbus head unit in my car (the VW RNS 510's Škoda cousin )
My car has a factory fitted DSP with the 12-speaker sound system. Here is a picture of the DSP:
I have read through the entire thread and I am ready to pull the trigger on an RCD330 with android auto, but I just wanted to make sure it will work with my car's DSP - I have read that people have managed to get it working with Dynaudio / Fender sound systems by disconnecting and re-connecting the battery - will this trick also work for my car? My hope is that since the RCD330 works with the VW sound systems, it can work with skoda's as well?
Here are the coding values I have applied to my Columbus to get it working with the DSP
BYTE 1: 02 Skoda Sound System (CAN DSP)
BYTE 2: 00 Sound System (active speakers)
BYTE 4: 01 Speaker Monitoring: Inactive (Sound System)
BYTE 5: 01 Equalization: Seat Altea (5P) / Skoda Octavia (1Z)
My concern is BYTE 1:
the skoda sound system is marked as CAN DSP, while the VW/Dynaudio/Fender sound-systems are marked as BAP DSP - dunno what this entails
Your inputs are greatly appreciated
Here is an autoscan of my car if it is of help (truncated to show the radio and sound system modules as not able to post it fully due to character limit):
Code:
Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb
Part No SW: 3T0 035 680 G HW: 3T0 035 680 A
Component: RNS-MID H42 5238
Revision: AB001001 Serial number: SKZ6Z7L9014015
Coding: 08020040010100A00000
Shop #: WSC 33361 790 00999
VCID: 346D228B97A1AFE65E-8060
3 Faults Found:
00856 - Radio Antenna
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 222
Reset counter: 158
Mileage: 119520 km
Time Indication: 0
00821 - Antenna 2 for Radio (R93)
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 130
Reset counter: 158
Mileage: 119520 km
Time Indication: 0
00862 - Antenna for GPS Navigation (R50/R52)
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 195
Reset counter: 158
Mileage: 119521 km
Time Indication: 0
Date: 2017.11.04
Time: 11:28:20
Address 47: Sound System Labels: 1Z0-035-456.lbl
Part No SW: 1Z0 035 456 HW: 532 226 800
Component: SK35-DSP 4 1000
Revision: 4 Serial number: 00012413
Coding: 0000000001
Shop #: WSC 73430 790 00000
VCID: 72E1E4936D35E1D68C-8026
2 Faults Found:
00872 - Bass Speaker Rear Left (R15)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 20
Reset counter: 255
Time Indication: 0
00420 - Front Right DSP Midrange Speaker (R104)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
A
Address 56: Radio (J0506) Labels:. 1T0-035-680.clb
3 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Reset counter: 158
Mileage: 119520 km
Time Indication: 0
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Reset counter: 158
Mileage: 119520 km
Time Indication: 0
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Reset counter: 158
Mileage: 119521 km
Time Indication: 0
Date: 2017.11.04
Time: 11:28:20
