Page 18 of 55 FirstFirst ... 8161718192028 ... LastLast
Results 171 to 180 of 548
Thread: Replacing RNS 510 with RCD 330+
  1. #171
    Aug 2017
    The fader could be because it is either not correctly coded for the amp, or does not support it.
    In the coding byte for amplifier in the RCD330, try changing to 03, reboot and test. if that doesn't work try 05 and reboot.
    What bit and byte is this under?
    Sent from my MI 5 using Tapatalk
  2. #172
    I don't have nor have I ever seen an RCD330 but I believe you can use the RCD510 coding label file?
    Might be in byte 2?
  3. #173
    Jan 2010
    thanks Kamold, appreciate your help!
    Another question, the AliExpress seller gave me the supposed 'camera adpator' below
    Replacing RNS 510 with RCD 330+-cam-adapt-jpg
    Which doesn't seem to be the correct one, as everyone else with OEM camera's have been linking this - Volkswagen Factory Backup Camera RGB to RCA Video Output Converter
    Which one do I need?
    Also where does this plug into the head unit? As the only 2 plug points on the back of the head unit already have connectors attached (Left is the quadlock plug and right is the FM antenna)
    Replacing RNS 510 with RCD 330+-back-jpg
  4. #174
    May 2007
    golf2001, nice write up. Once the bugs are gone I am sure this will be a great unit!
  5. #175
    Quote Originally Posted by golf2001 View Post
    If you have an OEM camera with the 26 pin multimedia connector which connects to the RCD510/RNS510 then you need the RGBS to composite converter you linked.
    If you are using an aftermarket or MY16 Tiguan camera with composite video (single yellow RCA connector) then you use the adapter you circled, and put that blue square connector into the appropriate block in the quadlock harness.
    Any luck with the amp coding?
  6. #176
    Jan 2010
    I have the 26pin OEM camera, so I'll buy the connector I linked.
    I haven't tried to change the amp coding yet, as I don't have an obd11 or rosstech cable yet.
    Some more information on the volume/fader issue. I noticed when I drove the car earlier today, that all of the settings for the head unit reset with each start. Things like speed volume compensation, audio muting for voice etc etc. So I am assuming the radio reverts back to stock settings each startup. Not sure if that is helpful information or not?
    Thanks for everyone's help thus far. If I get it up and running 100% I'll do a complete write up for everyone to follow.
  7. #177
    Oct 2017
    Ashgrove, Queensland
    Hi mate, i've just bought a 2010 Tiguan, seems there is no bluetooth to be found, i have the rcd310, was looking at purchasing the 9w7 until i came across your post, will the 330 plus work directly in the tig, does it just plug and play or what? I am trying not to spend too much, dealer wants around $800 just for 9w7 and install, aftermarket want around $650, any help would be much appreciated, as I've seena 330 on ebay for aroun $300, do I need anything else for install? Cheers for any help
    2010 Tiguan 125TSi 4Motion
  8. #178
    Nov 2009
    Cook, ACT
    Similar bugs here ..
    Fader defaults to front left speaker most power cycles.
    BT has all sorts of start up and operational glitches
    Volume audio sometimes works
    Android Auto can't list music folders otherwise no too bad compared to BT.
    Bleeps loudly 5-6 times on start up always.
    Screen not bright enough for direct sun... doesn't store settings?
    Seller is deferring to VW for software update...no dates given.
    About to pull it and refit the original 310.
    Promising but total PIA. 3/10.
  9. #179
    Aug 2017
    Might be in byte 2?
    Hey Kamold,
    Tried all the bit and bytes for radio to rectify the fader and sound issues and non of them seem to do anything other than reset/ restart the headunit.
    Seller said it is a firmware issue so maybe it can't be fixed with some simple coding?
  10. #180
    Quote Originally Posted by StanliMK6 View Post
    Hey Kamold,
    Unfortunately then it appears they suffer from the same software issues as countless other cheap Chinese head units ie lack of support for buggy releases
