So just to confirm, does this sync up to the steering controls of mk 6 golf? Got a 10' GTI mk 6 that doesn't have the bluetooth so this seems cheapest way to get that installed over getting a newer RNS.
I don't want to hijack this thread any more than I have it's a different unit.
More details will come soon otherwise I'm happy to discuss over PM
Hi All,
If anyone interested, purchase & installed a RCD330+ Desay unit on 2011 Passat. ($145 delivered DHL-6 days delivered)
Climatronic not showing in screen
Full Ops is active(front, rear and side)
Use same connection as Rcd510
Steering button works except (rhs) which still active and working with originally fitted bluetooth.
LHS button for volume, answer calls and mute is working ok.
*Coding required for backup camera
*There is a error on CAN getway due to incorrect coding on RCD330, (but this is not affecting any functionality)
*still error on original bluetooth as disconnected audio cables from back of the unit. (possibly need power disconnected and removed from can Getway)
*required 2 to 1 antenna cable as no AM reception
*show caller number in dash display
***Mirrorlink works ok with Android phone, if you search the internet, there is a way to mirror the phone to use any application through Mirrorlink. (tomtom, google navigation, google car play, all works ok except some time screen flashes for few times.
Please share any coding and tricks if you aware to make it 100% integration
Hi all - new forum member here! I just installed one of these head units in my MY08 MkV GTI, based on feedback from everyone in this thread. I bought from this link:
https://www.aliexpress.com/item/Carp...02804-VnYZvQVf
Shipping took less than a week, which was a pleasant surprise. It seems to work just as it should, and shuts off with the key, which suggests I don't have any CANBUS problems - my CANBUS gateway's part number is 1K0907951, FWIW (I think this is the part that came in all MY08 Golfs with the full-height red MFD). I would have been happy to spend $300 just to add an AUX input, so for the functionality this thing offers, it might be one of the best tech purchases I've ever made.
I've got no experience with car audio installations, but with a set of trim removal tools, I think this took about 20 minutes all up to install. It looks like it was made for the car, and I think the sound quality might be better than with the RCD500 it replaces (it sounds like the mids are a bit stronger, but that might be subjective).
Thanks to everyone on this forum for the tips and links! Here's the final install:
I'm now thinking about replacing the RCD310 in my Mk6 Comfortline with an RCD330 but have only just discovered this unit so am curious. What is its origin? Are they made for Chinese VWs?
If it's plug and play and supports CarPlay then it almost seems too good to be true given the price. The stock look of the unit is a bonus too.
2009 Mk6 Golf 103TDI- Silver Leaf
I think they're made for Chinese and Malaysian Polos, Ventos and Beetles - I'd guess that they're just removed from new cars by VW dealers if buyers want to upgrade, and then resold to us, which would explain why they're so cheap. If you've got a Mk6, it should work with your steering wheel controls, too.
Yep, plugged in my Samsung S5, nothing, battled for a day, ended up loading the LG Carplay app, opens and flikkers for a minute, then I get the Samsung screen, because there are nou "back" button you can only open apps, not close them, unless you load another app on your phone "Button Saviour" anf then, when you unplug the phone just hangs. Useless gadget, but the radio overall isnt that bad
There seem to be some workarounds people have found: https://www.youtube.com/watch?v=orR5QX3tJmg
2004 MK4 R32 - Reflex Silver - KW V3 - AdvanSport V105 - Colour Matched RCN210
2012 up! 3Door - Tornado Red - More details soon…
