Hmm just realised car image not showing up, will go through VCDS
https://www.autoevolution.com/news/g...es-143427.html
Incase Android Auto not working appropriately for anyone.
[QUOTE=sn809;1313558]@Richmurphy, do you want to put in a low resistance to see if the small voltage fluctuations get ignored?
I tried using a 330 ohm resistor I had lying around. The camera didn't open. Unfortunately it didn't open when I engaged reverse either!
Obviously 330 ohm is too high - might check the current draw and work backwards. I'm actually surprised the bulb check didn't fail so I might look closer at that too.
There is also a cold diagnosis back up light option in vcds, you could try disabling that on vcds at your own risk though
I'm sure this question has been asked befoer, but I can't find any info. I've just bought an RCD340, installed it and it's great. The OEM rear camera isn't working as I'm not sure how to plug it in. Is this going to require a new aftermarket camera and an auto-electrician to wire it in or can I do it myself and can I use the OEM camer? thanks
Yes, there should be a yellow connector with a blue pin connector at the end. The pin connector goes under the Speaker jack and the yellow one should link up with your OEM camera.
Sorry not sure what you mean. The OEM camera doesn't have an RCA plug, actually I have no idea what plug or cable belongs to the OEM camera. Are you saying I should buy a new camera and ditch the old one?
New cable that came with RCD 340 that connects 340 to the RCA port on the reverse camera except my OEM camera does have RCA
Main RCD 340 Port
Remaining plugs from RNS 315 that won't plug into RCD 340G, not sure what they are, large 24(?) pin black plug and blue plug
Old RNS 315 ports
