Page 47 of 55 FirstFirst ... 374546474849 ... LastLast
Results 461 to 470 of 548
Thread: Replacing RNS 510 with RCD 330+
  1. #461
    Adelaide hills, SA
    Quote Originally Posted by MEL744 View Post
    Considering buying one of these for my 06 Jetta, just wanted to make sure I have the right idea of what needs to be done before purchasing. Currently undecided between the A or B model, not sure if the Android Auto is worth the extra cost, if I do get a B model I plan on buying the cheaper noname version with MirrorLink and Apple Carplay then reflashing the firmware to one with Android Auto. Can someone confirm the following list should work with my car:
    - Steering wheel adapter for 8 button steering wheel (my car has half height MFD if this makes a difference?)
    - Dual fakra antenna adapter
    - Updated Canbus: for this I was planning on getting one from a newer mk5 at the wreckers then just recoding it with VCDS to match my car - will this work?
    Cheers,
    Michael
    Yes, it will work.
  2. #462
    Mar 2015
    Central Coast, NSW
    Have been following this thread for at least a year now - I have noticed in the last few pages that there is mention of the OEM RVC working with the 330+ if it is not the 'highline' model
    I have a MY10.5 Mk6 Golf GTI, RNS510 as stock with the emblem RVC...my camera does NOT have the guidance lines - just video.
    Am I correct in saying that I can use the 330+ with a video adapter? This is new to me if so.
  3. #463
    Yes you can use a lowline rvc with a rgbs to cvbs converter
  4. #464
    Sep 2010
    Melb
    Quote Originally Posted by Mk R View Post
    Disconnecting the under seat bluetooth is required as you'll no longer need it and it will conflict with your new RCD330, which has bluetooth and microphone inside the stereo unit.
    After disconnecting the bluetooth module, can I just leave the cable hanging? I assume there's no other tweaks required to tell the car that the old module isn't required anymore?
    Golf R 5 door United Grey | DSG | ACC | Leather | Bluetooth | 19" Talladega Black
  5. #465
    Dec 2006
    Kilsyth, VIC
    Quote Originally Posted by m_f View Post
    I would guess that the CANBUS would report a communication error since it can't see the bluetooth module, although I don't think you would ever see it on the dash. Worth coding out if you have access to a VCDS cable somewhere, but not the end of the world otherwise.
  6. #466
    Sep 2010
    Melb
    Quote Originally Posted by The_Hawk View Post
    Thanks heaps!
    I don't have access to VCDS cable unfortunately. Will disconnect the bluetooth module when I get the unit
  7. #467
    Nov 2019
    Oem Camera hookup rcd330+
    If you have an OEM camera with the 26 pin multimedia connector which connects to the RCD510/RNS510 then you need the RGBS to composite converter you linked.
    If you are using an aftermarket or MY16 Tiguan camera with composite video (single yellow RCA connector) then you use the adapter you circled, and put that blue square connector into the appropriate block in the quadlock harness.
    Any luck with the amp coding?
    With this adaptor, where does the camera plug into?
  8. #468
    Dec 2006
    Kilsyth, VIC
    Quote Originally Posted by leechy70 View Post
    There will be a round (usually yellow) RCA plug on the back of the unit.
  9. #469
    Nov 2019
    I have this blue plug?Replacing RNS 510 with RCD 330+-img_20191122_080358-jpgReplacing RNS 510 with RCD 330+-img_20191122_080358-jpgWith the mention kit, not sure how to use this with the yellow female video plug?
  10. #470
    BLue plug is GPS antenna - you don't need that.
    The 26 pin connector you have is the multimedia connector which includes camera.
    You need to plug this into the RGBS-CVBS adapter and the RCA video cable from that plugs into your RCD
