Page 46 of 55 FirstFirst ... 364445464748 ... LastLast
Results 451 to 460 of 548
Thread: Replacing RNS 510 with RCD 330+
  1. #451
    Apr 2019
    I own a Golf R Mk6 with reverse camera and dynaudio.
    A bit of confusion, however from what I gathered, the RCD330+ will give me degraded sound quality and lose ability to use MFD.
    However, the pros are that it integrates with the stock reverse camera and has CarPlay?
    Please let me know if I’m missing something as I’ve been hesitant to bite the bullet thus far
  2. #452
    Quote Originally Posted by 7smurfs View Post
    You're correct apart from the reverse camera. If it's highline (bending guidelines) then not compatible. You'd need to replace the camera and control module.
    If it's lowline then you can use a rgbs to cvbs converter.
  3. #453
    May 2019
    Ontario, Canada
    Quote Originally Posted by Jakeys View Post
    Also, I found another bug with the unit, if you have a max startup volume (Same as the RNS510 had) configured, every time a voice prompt comes through on Android Auto like say a navigation prompt, it resets the volume back to your max startup. So you may need to just turn that feature off if you're using Android.
    I'm being nitpicky bringing these bugs up, I think the unit is amazing.
    There is an update out, 5516, only for NoName that fixes the resetting volume issue. It adds a separate Voice Operation Volume control. It also fixes a few of the other bugs.
  4. #454
    Aug 2019
    Brunswick
    Hi all,
    I'm hoping to install the RCD330+ in my 2013 Passat alltrack. I've been holding off, waiting for a solution to the highline reverse camera problem which seems to have been going on for a couple of years now. I have a couple of questions for the hivemind:
    1. Has anyone tried this Xtrons decoder for a highline (bendy guideline) reverse camera (XTRONS CAMDCV01 Reversing Camera Decoder Box for VW Volkswagen Passat-in Car Diagnostic Cables & Connectors from Automobiles & Motorcycles on Aliexpress.com | Alibaba Group)? Xtrons themselves arent too clear when I asked.
    2. is there a solution for installing an aftermarket camera that doesnt require running a new wire from the camera to the headunit? eg, can I install a new camera using the existing OEM wiring and then attach this to the RCD330+?
    3. can anyone recommend a decent VW mech in melbourne who can assist with some other mods (eg. upgrading park pilot to park assist)
    Sorry if these are simpleton questions, im new to this forum.
    Thanks!
  5. #455
    There is no solution for the factory highline camera with an rcd330.
    I've used an aftermarket can rvc with discover media which works well.
    In theory it's the same generation head unit so should also work.
  6. #456
    Aug 2019
    Hi guys, long time listener, first time caller....
    I recently purchased and installed an RCD330 into my 2010 R36.
    I mistakenly purchased the Desay version.
    Very happy with it, apart from the balance fader not being able to activate the rear speakers.
    I think the other day whilst listening to music, I activated the camera on my phone, and music was
    then softly playing through the rear speakers only.
    I was thinking of returning it, and purchasing a No Name instead.
    So my question is...
    Is there an easy fix for this problem with the Desay? Does the No Name have the same problem?
    Or should I get the No Name for more reasons, among the ability to update firmware?
  7. #457
    Jun 2015
    Liverpool, NSW
    Quote Originally Posted by Dams View Post
    I have the Desay version... everything works great so far..... i did have an issue with carplay (wouldn't connect after changing usb cable) but I reset the unit and everything is working fine now.
    hold down the power button for 5-10sec and then let go, you should see it reboot - this fixed my carplay issue.
    Current 2023 T-Roc R-Line 140TSI | Past 2015 Jetta Trendline 118TSI
  8. #458
    Aug 2019
    The Desay worked great for me, except the rear speakers not working.
    I've returned it and am waiting for the no name I've ordered to arrive, bit slow posting this one.
    The rear speakers might not work with the no name either, but I'm hopeful this can be fixed.
    I ordered the no name mostly because of the firmware update ability,
    apparently there's a new version of carplay being released soon....
  9. #459
    Aug 2019
    So I got the No name version, had issues with beeping on start up, fader all the way on front left speaker
    at every start up, and couldn't adjust equalizer which made the sound terrible.
    Updated firmware and all issues fixed.
    Easy.
  10. #460
    May 2016
    Melbourne, Victoria
    Considering buying one of these for my 06 Jetta, just wanted to make sure I have the right idea of what needs to be done before purchasing. Currently undecided between the A or B model, not sure if the Android Auto is worth the extra cost, if I do get a B model I plan on buying the cheaper noname version with MirrorLink and Apple Carplay then reflashing the firmware to one with Android Auto. Can someone confirm the following list should work with my car:
    - Steering wheel adapter for 8 button steering wheel (my car has half height MFD if this makes a difference?)
    - Dual fakra antenna adapter
    - Updated Canbus: for this I was planning on getting one from a newer mk5 at the wreckers then just recoding it with VCDS to match my car - will this work?
    Cheers,
    Michael
