Page 45 of 55 FirstFirst ... 354344454647 ... LastLast
Results 441 to 450 of 548
Thread: Replacing RNS 510 with RCD 330+
  1. #441
    Aug 2017
    Quote Originally Posted by klose View Post
    Looking at upgrading my factory RCD510 to the 330plus in my MK6. What can I expect not to work in it regarding MFD display and steering wheel buttons
    Everything on mfd radio related is gone, the oem Bluetooth system basically useless as it runs off the rcd330 head unit.
    Steering wheel buttons will work as normal, sound up, down, changing to the next radio station, mute and picking up Bluetooth calls.
    Sent from my SM-G965F using Tapatalk
  2. #442
    Mar 2019
    NORTHCOTE
    So am i right in saying that this unit will swap straight out my RCD310 unit and give me bluetooth music and calls?
    Do i then lose my DAB radio though?
    Seems like a great cheaper option!
    Thanks in advance.
  3. #443
    Nov 2018
    Wollongong, NSW
    Hi guys.
    I currently have this unit in my MY15 Polo. Firstly, what model is it?
    Secondly, I wish to upgrade to have Android Auto, and considering I have no Steering Wheel controls, and no Reverse Camera, (Although might install a camera at a later date), will any RCD330+ from Aliexpress be what I need?
    Cheers Guys.
  4. #444
    Aug 2017
    Quote Originally Posted by Milo View Post
    Hi guys.
    Cheers Guys.
    The rcd330 will not fit your model.
    Only mk6 and mk5 platforms is compatible with rcd330; with either rns510, rcd510 or similar installed.
  5. #445
    Hi guys.
    Cheers Guys.
    It's a Composition Colour.
    If you want App Connect you would need to upgrade the head unit (its in the glovebox) and the screen to either Composition Media or Discover Media/Pro.
  6. #446
    Mar 2019
    I wonder if there is solution for 330 to work with the Dynaudio system with Blaupunkt amp yet? From crawling through forums some said it's fine but it doesn't seem to be a proper fit. Would appreciate any advice.
  7. #447
    Quote Originally Posted by ymmf View Post
    Rcd330 can't be configured to output line level balanced output for an amp (doesn't have suitable circuitry as part of the design)
    You can use a line out converter like with most aftermarket head units.
    RCD 510/RNS510/Discover Media units are designed to properly work with factory amps by switching output from speaker level unbalanced output internally.
  8. #448
    Mar 2019
    I'm not familiar with the wiring but how possible is it to get a line out converter to work with RCD330+ and the Dynaudio amp?
    It looks like an aftermarket headunit with Aerpro CAVW01 adapter is the only way to go? I thought about Maestro RR but apparently it only supports North American headunit models...
  9. #449
    Mar 2019
    Sarajevo
    Purchased a Touran 2011 Highline yesterday that came with an aftermarket android head unit. I dislike it as it really looks non-OEM.
    Found about RCD 330 today (had an rcd 320 previously on golf mk5).
    Will the rear camera and park assist work out of the box?
    I assume it's easiest to buy the one with Android Auto if I need it (and not bother with updating firmwares).
  10. #450
    Mar 2015
    perth wa
    Quote Originally Posted by ribice View Post
    Only ntsc cameras work and park assist should work
    Sent from my SM-G950F using Tapatalk
