Page 40 of 55 FirstFirst ... 30383940414250 ... LastLast
Results 391 to 400 of 548
Thread: Replacing RNS 510 with RCD 330+
  1. #391
    Sep 2014
    It's not bizarre.
    Rcd330 doesn't work with a highline module because they don't know how to talk to each other.
    A lowline camera is a simple video output so that works with a converter.
    Unless someone comes up with a can converter to allow the rcd to talk to an older rvc control module you have to remove the highline module and connect the video feed straight from the camera itself or install any aftermarket camera.
    So the mk6 gti has a high line module hey? I thought it was a lowline. I don't have the moving guide lines, would this indicate this?
    Sent from my SM-G955F using Tapatalk
  2. #392
    Ok if it's lowline then in theory it should work. Does the RCD have an adaptation channel to set the RVC input mode?
    If so it should be set to FBAS (composite).
    If that doesn't work you'll need to use an aftermarket camera.
  3. #393
    Sep 2014
    I'll have a look in a bit, I don't remember seeing one however it was quite some time ago that I looked.
  4. #394
    Sep 2014
    Quote Originally Posted by ZantetsukenJ View Post
    There's nothing unfortunately.
  5. #395
    Jun 2018
    I'm with you on the same boat. I'm pretty sure my rvc is low line because I don't have guiding lines. Irritating lol.
  6. #396
    I have had a random thought bubble that might be worth testing (I don't have an RCD330 so can't test this theory sorry..)
    It's possible that the head unit is switching to the reverse image TOO FAST for the camera to provide an image. If the head unit doesn't get an image immediately it blanks the display.
    So the existing OEM camera setup whilst fast enough for the older head units which took maybe 800ms to switch to reverse image by which time the relay had been triggered and the image was being sent from the camera....is too slow for the newer head unit...
    So how do you test this? Either supply constant 12v to the camera rather than reverse switched, or try running power to the camera itself from a digital delay relay triggered from the reverse light circuit. Give the relay constant 12v (eg from the boot release motor).
    Use something like this which doesn't have the sort of delay associated with an old school traditional relay:
    GreenYi RVC Delay Timer Relay Filter for VW RCD330 Passat Tiguan Golf Touran Jetta PQ MIB Conversion Cable for Rear View Camera on Aliexpress.com | Alibaba Group
  7. #397
    Sep 2014
    Good idea, the head unit does switch to the camera image slightly before the camera flips up. I may be able to test soon when I have a free moment
  8. #398
    Make sure you clear faults on the rcd330 and reboot it prior to testing and each time you change something.
  9. #399
    Jun 2018
    So how are people finding the audio quality/bass from this head unit? Currently have the RNS510 in a 2012 1Z Octavia and for a stock system it sounds bloody amazing with tonnes of bass, makes my old mk6 look pretty average and a stock mk7 system look super lame. I don’t really want to lose that. I’ve read (correct me if I’m wrong) the RCD 330 has 4x20w output which is the same as the RNS510, does that output change depending on which of the 4 RCD330 models it is? I’m guessing there are also other factors at play with quality and amount of bass also though.
    Thanks.
  10. #400
    Oct 2014
    Quote Originally Posted by Pe88lz View Post
    Thanks.
    I went from the genuine Bosch RCD510 to the Desai RCD330 CarPlay in my Mk6 Golf. My sound quality was marginally better with the RCD330 if anything. It has a richer top end and i can still push the bass beyond the range of my speakers. In the Golf I had good speakers from the factory (much better than those in our Tiguan which I also upgraded from the RCD310 to RCD330. The Tiguan Sound also improved but the sh*tty speakers limited the quality in the bass to mid range).
    There's only one case here i've heard of here where the sound quality was worse from an RCD330 and I'm guessing that's a defective unit.
    If you're getting great bass out of your octavia it's also a sign of good quality speakers and in my opinion it's unlikely you'll lose that unless your unit is defective or your equaliser is adjusted poorly.
    At the end of the day these units are pretty cheap (AliExpress) and if you don't end up liking it you could sell it very easily (Probably for a profit) on ebay or gumtree.
