Page 35 of 55 FirstFirst ... 25333435363745 ... LastLast
Results 341 to 350 of 548
Thread: Replacing RNS 510 with RCD 330+
  1. #341
    Sep 2010
    I've just fitted an RCD330 into my car today. Boot up is very fast, load times off of all media (BT/USB/SD) is quick too.
    How can I tell if it's a Desay unit or not?
    The labels on the unit itself don't reference 'Desay' at all - it's AIUAUDIO(?) unit, which I assume is the 'no name' one??! However some forum posts on RCD330plus.com with the same HW and SW references indicate that it IS a Desay unit??!
    Mine is the following revision - 6RD 035 187A and came with SW version 0210
    I want to know so that I can attempt to update the firmware to support Carplay. Otherwise, I'll just keep on using it as is.
    '18 MY18.5 MK3.5 Octavia vRS245
    Previous - 2015 MY16 MK7 R, 2010 MY10 R36 DSG, 2010 MK6 Golf GTI DSG // APR Stage 2, 2006 MK5 Jetta TFSI DSG // Revo Stage 2, 2006 MK5 Golf GTI Manual
  2. #342
    May 2009
    Frankston, Vic
    Feb 2018
    Austin texas
    Well this might have been converted but i got to the 12 page and said screw it.
    I’m putting in a rcd 330 in my 07 gti. I ordered my canbus (1k0 907 530 L) my question is is do i have to recode the module or can i just put it in and call it good? How hard is the recode? Is there anything i need to watch out for specifically? Are there any threads on recoding? Please let me know. Pm are welcome as well. Thanks again guys.
  4. #344
    Quote Originally Posted by JJ_LePine View Post
    Yes the new gateway needs to be coded to match what is in your car. Takes 5mins.
  5. #345
    Oct 2014
    James: first one is version E, has android auto native.
    Second one is a version B, Noname, upgradable to AA
    3rd is version B Desay, not upgradable to AA
    This one is Version B, already upgraded. I just bought one. Hasnt arrived yet
    Crngiar RCD330 RCD330g Plus R340G 6.5"MIB Radio Carplay App Android Auto For VW Tiguan Golf 5 6 Ameo MK5 MK6 Passat Vento Touran-in Car Radios from Automobiles & Motorcycles on Aliexpress.com | Alibaba Group
  6. #346
    Jan 2018
  7. #347
    Oct 2014
    Quote Originally Posted by Denzark View Post
    No. Fixed by four T20 torx screws. I doubt you'd find a single phillips head screw on a golf.
  8. #348
    Jan 2018
    thanks figured as much T20
    ill check if i have it or need to get it
  9. #349
    Sep 2010
    After successfully using the fuse mod to prevent battery drain with the RCD510, it seems that it doesn't work with the RCD330+ so my battery is draining.
    Therefore I will need a new CANBUS gateway and coding. Is there anyone in Sydney that can do this? Please PM me!
  10. #350
    Jan 2018
    Have received the rcd330+ unit today.
    took about 10 minutes to install.
    Yet to get Android Auto/Mirrorlink (using s7 edge) to work (wondering if i have a bad usb cable)
    the radio asks me to connect phone which i do, phone makes noise and shows a charging icon but the radio does not progress off that screen.
    will try another usb cable
