Page 29 of 55 FirstFirst ... 19272829303139 ... LastLast
Results 281 to 290 of 548
Thread: Replacing RNS 510 with RCD 330+
  1. #281
    Jan 2010
    Quote Originally Posted by ZantetsukenJ View Post
    All good, but sorry if mine is similar in a tone:
    "Did you also connect the ground wire to an earth point?"
    - There's actually no ground wire
    "Which circuit did you use in the fuse box?"
    - I plugged it both into the cigarette lighter fuse and also tried the radio fuse
    "Does that circuit actually have an active switched 12v supply?"
    - Well I assume so, not sure why you'd have a fuse adaptor otherwise
    "Is the fuse plugged in the right way up?"
    - Yeah man, it's in there tighter than Mike Tyson and my friendship
    "What is in the link on the end of the power wire is an 'add-a-fuse' which is meant to piggyback off an existing circuit such as the 12v accessories fuse (cigarette lighter) and then you plug the existing fuse into the second fuse holder in your add-a-fuse"
    - Wait, you just asked me "Does that circuit actually have an active switched 12v supply?", sorry but what?
    Sent from my SM-G955F using Tapatalk
    Hey mate, not sure about your connector, but with the connector I bought (26 PIN RGB to CVBS (RCA) AV Converter for Volkswagen Factory Original Camera Output to After Market Head Unit DVD-in Vehicle Camera from Automobiles & Motorcycles on Aliexpress.com | Alibaba Group) you need to wire the +12V to power and the red and yellow wires into pins 6 and 12 of the B block of the quad-lock connector. The red wire carries the signal for the camera to my knowledge.
    Not sure if that helps or not?
  2. #282
    Sep 2014
    Quote Originally Posted by golf2001 View Post
    Hmm it does.
    I might give it a go. Looks like you can skip the yellow and red and just use an RCA to MIB connector instead.
  3. #283
    Without a ground I'm confused as to how this converter is supposed to work. Did they supply a wiring diagram?
    You are getting 12v from a known switched (as opposed to constant) 12v power source (accessories), but without a ground there is nowhere for the voltage to flow to....the 26pin multimedia connector does not have a ground pin.
    The polarity of the fuse is important. Is the 'tail' of your add-a-fuse pointing up or down when installed in the fuse box?
    The RGBS to composite converter requires a power source, it won't do any converting if you just plug in video in and video out.
    I've used the one from Aliexpress and it works very well. You tap 12v power and ground from the quadlock harness going into the radio, then ignore the 'reverse' wire.
  4. #284
    Sep 2014
    My thoughts too, I didn't know how exactly it's supposed to be powered as such.
    Polarity is fine, I had it the right way.
    Yeah I know, the fuse I tried was the stereo and cigarette lighter fuses, both were working when I replaced it with the fuse holder so I assume there's power running through the fuse.
    I might look at what you are currently using then, and see if that works. Thanks for the help!
  5. #285
    Jan 2012
    Hey guys, need a little help.
    From what i gathered, the 187B model is the one that comes with Android Auto and Car play.
    Im looking to purchase this one:
    Crngiar6.5" MIB Carplay App Car Radio RCD300 RCD510 RCD330 RCD330g Plus For VW Tiguan Golf 5 6 Jetta MK5 MK6 Passat Polo Touran-in Car Radios from Automobiles & Motorcycles on Aliexpress.com | Alibaba Group
    My car is a 2007 golf GTI.
    Will i need both the ISO quadlock and CAN bus? if so can i purchase this?
    Aliexpress.com : Buy RCD330 Plus MIB RCD330G Plug&Play ISO Quadlock Adapter Cable Wire CANBUS Simulator For VW Golf Jetta 5 6 MK5 MK6 Passat B6 Polo from Reliable simulator cable suppliers on HEYCAR UPGRADE CLUB Store
    Is this anything else i would need to be concerned about?
    From my understand, the steering wheel buttons will not be usable?
    Thank you kindly
  6. #286
    Dec 2017
    Almaty
    Quote Originally Posted by alch3mist View Post
    This one does not support Android Auto, only Carplay, there are two types of 187b with different hardware
    probably you don't need it, what is your stock headunit?
  7. #287
    Dec 2017
    unk
    Quote Originally Posted by bubba View Post
    The WeTransfer link are down (Transfer deleted)
    Could someone re-upload, please?
    Thanks
    I've found
    LINKS:
    5515 RED: std_plus_pss-6.5inch_170421 5515 _VW_PQ_GP.tar - Google Drive
    5314 RED: std_plus_pss-6.5inch_1014 5314 _VW_PQ_GP.tar - Google Drive
  8. #288
    Jan 2008
    Camperdown, NSW
    A few questions.
    On page 21 someone wrote
    The actual unit with OEM Android Auto is 6RF 035 187C o 6RF 035 187E
    I can't see these on aliexpress. So I just get the noname 187B? Any one recommend a good seller at the moment? Previous links are no longer valid.
    I've got a mk5 gti with mk6 steering wheel so the buttons will work. Does the mfd still show the phone info and can a call be answered via the accept function?
  9. #289
    Dec 2017
    Oxford, England
    Quote Originally Posted by 0AM View Post
    Thanks
    I've found
    LINKS:
    Thanks, are the links you have provided for the Modified version bubba created?
    If not, could somebody please re-upload?
    I tried the 5515 version and it has bugs with sound going to front left and volume keeps dropping.
    Thanks
  10. #290
    Sep 2014
    Quote Originally Posted by pw1500 View Post
    Thanks
    5314 should be the correct version I believe
