Page 25 of 55 FirstFirst ... 15232425262735 ... LastLast
Results 241 to 250 of 548
Thread: Replacing RNS 510 with RCD 330+
  1. #241
    Jul 2010
    It works! Thanks for the tip on not needing to tap into the reverse light wiring to get the trigger.
    Can confirm no issues without the delay timer. All works properly on this version of the RCD330 (187b Cringar Android Auto).
    Now to run the wiring through the car...haha
    Sent from my SM-G955F using Tapatalk
  2. #242
    Apr 2008
    Nice.
    I don't think the loom in my B7 Passat has a wire there. Will have to check.
  3. #243
    Apr 2008
    Ah, I have the non Android Auto version.
    So you reckon the delay timer comes off the ACC wire?
  4. #244
    Apr 2008
    Are those lines on the screen from the camera, or the headunit?
    I have a factory boot button RVC, that I know has the yellow lines, but they don't show up.
  5. #245
    Jul 2010
    All done.
    Ran the wiring up the left hand side of the car, used the ground/earth at the rear left of the hatch area, soldered the black cable from the camera to a ring connecter suitable for the size of the ground post (which is held by a 10mm nut)
    Used a heavy duty T-tap into the power cable on the radio quadlock below the BAT+ cable (see pics in previous posts), red power wire (runs with the yellow video plug) into this tap. Soldered the other end of this at the rear of the car to the red power wire from the camera.
    Yellow RCA video cable is plugged into the head unit with the blue adapter that fits into a quadlock slot supplied with my head unit.
    When the car is placed into reverse, the camera pic comes up 1 second later on the head unit. Switches off after 8 seconds in a non-reverse gear or over 15km/h ish. No problems that would require the delay box. Lines don't move with the steering, just there for indication/decoration.
    Hope this helps someone else!
  6. #246
    Jul 2010
    Quote Originally Posted by benough View Post
    Unsure. I did read somewhere that the 187b may not need a delay timer, turned out to be true in my case.
  7. #247
    Jul 2010
    Possibly the camera. I had pre-installed this camera when I took the bumper off to do a towbar install. Couldn't see any options to turn the lines off at a quick glance in the headunit menu.
    Others may know more.
  8. #248
    You're not going to have the problem of the head unit getting confused when it loses the signal from the camera...because you aren't cutting power to it.
    You have it constantly powered ie the reverse camera is always on.
    This isn't the ideal way of setting it up as the iris on these cheap cameras are prone to burn out if constantly powered.
    The preferred solution is to tap 12v power from the reverse light circuit using a digital delay relay/filter.
    This will keep the camera powered for 10 seconds after leaving reverse so that if you are manouvering into a parking spot for example and you then go back to reverse, the camera is still powered so the head unit will still have the reverse image feed coming in.
    There is nothing wrong with powering the camera itself constantly as such, you just may find you cause the camera an early death and end up having to replace it.
    All factory solutions only power the camera when in use and switch it off then driving forward for this reason.
  9. #249
    Jul 2010
    I have the delay relay here still, might change the wiring over the weekend when I have a little more time.
    Relay is near enough to this one
    Replacing RNS 510 with RCD 330+-htb1vwb6qvxxxxb4axxxq6xxfxxx4-jpg
    So...just checking. On a Mk6 Golf, blue reverse wire to a reverse wire in the hatch door, black to ground point, red being + is it OK to continue using the headunit power feed I have (wire it to the relay obviously) or is there a better way?
    Does that sound right?
  10. #250
    Jul 2010
    Need to go through the c-pillar and hatch door for the reverse wire...ouch.
    Any better way?
