Update:
It is not possible to upgrade a stock 187B with the AA firmware via USB. When trying to update, the message 'Error: variant conflict' appears.
Thanks to RecZero for providing the firmware for the test.
Sorted - cheers!
Also...back to red.
Received my Crngiar 'R340' this morning ordered from Ali Express and installed it in about 10 minutes!
Can confirm it's a 187B unit with Android Auto and Apple CarPlay (and Mirrorlink). All works perfectly aside from AM radio, so it must have the improved firmware already on it. Sound quality at least on a par if not better than the Bosch RCD510 it replaced. My Samsung S8+ was picked straight up and all worked well streaming Spotify, "OK Google" navigating and replying to Facebook Messenger messages using voice while driving.
I didn't bother wiring in the composite reverse camera today, will tackle that another time. I just unplugged my quadlock and antenna leads from the RCD510 and put them straight on the new unit using the dual to single antenna adapter included with the new one. I'll have a look with VCDS later to see what shows up and turn off my old bluetooth hardware as the phone still connects to it.
My unit revisions are HW 534 and SW 5314.
Got into VCDS last night to check out the changes. The headunit is recognised by VCDS 17.8, I used it to turn the rear view camera off due to not using it at the moment. Options for speaker configuration are all there, it was using the same settings as the RCD510 had so I just left these alone.
The RCD510 media player (iPod connectivity in the centre console etc) had to be turned off using the installation list on the CAN gateway, easy enough. Only way to truly disable the factory installed bluetooth is to unplug it. I just reached under the drivers seat and disconnected it. This obviously removes the phone menu from the MDI.
One interesting item which may point to the true age of some of these units was discovered though. The headunit had an error code from a power or CAN disconnection at 27000km, my car has 110000+ on it. Could be a relic from hacked firmware though.
Sent from my SM-G955F using Tapatalk
Just wanted to post a big thanks to everyone in this thread for their insights and information. Recently replaced my RNS510 with the 330+ and the whole process was very simple and I’m loving the extra functionality CarPlay gives me.
I’m also experiencing a few minor bugs with the volume fader settings not being remembered but it sounds like a firmware update might be on the cards in the near future from what others are posting (I’m on HW 534 SW 5314).
