Sounds to me that you have a basic Bluetooth module if it only lets you answer and hang up the phone. The 9w7 will give you that functionality plus full streaming capability on an RNS- and RCD-510. It should just be an matter of replacing one for the other and a bit of coding.
Did your car have GPS from the factory? Sounds to me like something has gone wrong with either the antenna or the RNS-510. Have you tried rebooting the head unit? If that hasn’t worked, perhaps a firmware upgrade or antenna set replacement would do the trick.
Daily: 2010 Tiguan TDI | Candy White | Manual | 4MOTION | New York Wheels | Comfort Pack | Tinted Windows | Discover Media | MkVI MFSW | Mk7 Climatronic | RVC | Fog Lights | ECB Nudge Bar | Hella 160 Driving Lights | Rola RBXL135 Cross Bars | To Do: Colour MFD
Toy: 2008 GTI Pirelli | Sunflower Yellow | 3 Door | DSG | Pirelli Wheels | RNS-510 | 9W7 Bluetooth | RVC | Rear Sensors | Fog Lights | To Do: Mk7 Climatronics, MkVI MFSW, Colour MFD
- does the RCD330 work with OEM reverse camera and sensors? Yes I have the oem camera and it works great. You need an adaptor and if you are handy with electrical work (I wasn’t) it is pretty straightforward.
- does the RCD330 work with Dynaudio? Yes- over at mk6 forum all they had to do was disconnect and connect their battery for it to work
- I assume it's a direct plug and play? Yes mostly, VCDS coding is pretty easy.
- I assume GPS is redundant with carplay/android play? Was skeptical about apple maps but if you are in a major city, works perfectly
- can you get a unit that does both android and apple? (Work phone is iPhone and personal is Samsung)
Head over to the golfmk6.com forum, they have a pretty epic thread and a number of people have changes from RNS510 to this. I highly recommend it- Bluetooth quality and functionality is fantastic
Past - 2006 Mk5 R32, 2012 R56 Mini Cooper S
Current - 2010 Mk6 GTi - Build Thread
Hey, really interested in the RCD330G/340? Android Audio for our 2009 TDI Tiguan.
Recently I was introduced to auto' tech' Ford Sync2 in my Focus Mk3 RS and kinda like the features (even though Sync2 is actually *****e).
Couple of questions I'm unclear about having read this and plenty of the linked threads.
I've seen some small display units with CD - does anyone know traps here for young (old) players. Too Old Skool???
Is the car wired for a reversing camera with the boggo 310? system or will I have to run (or pay to run) new cable?
I'm unclear if the 330G/340 has navigation (I think it might) or that isn't an issue because Google Maps is available?
Does the units radio work with Aust radio frequencies?
Car is probably on the battery drain cusp age - how do I confirm the need for a battery anti drain thingy?
Hey arsenalroc I had a question on how you connected the rear view camera.
I have an OEM camera on my tiguan and purchased a rgb to cvbs adapter but cant get it to work. I have tried everything from what others have said and I cant get it. Do you have any tips. This is the one i purchased:
Volkswagen Factory Backup Camera RGB to RCA Video Output Converter
I am thinking it may just be the adapter is bad. Do you have a link to the one you used?
Thanks in advanced
Hi. Do you have any information about this unit? I will install it to my KM7. AIDUAUTO For VW Golf 7 MK7 VII Passat B8 MQB Tiguan Carplay 6.5 " MIB Radio-in Car Radios from Automobiles & Motorcycles on Aliexpress.com | Alibaba Group
