Page 15 of 55 FirstFirst ... 5131415161725 ... LastLast
Results 141 to 150 of 548
Thread: Replacing RNS 510 with RCD 330+
  1. #141
    The fact that your RNS worked fine would tend to suggest there might be an issue with the rcd330. But you'd need to test it in another car to know for sure
  2. #142
    Sep 2017
    Yangon
    Yeah. I need to check with another car as you suggested. That is the only thing I left to do.
  3. #143
    Apr 2008
    I've just put the RCD330 + into a 2011 B7 Passat Highline Variant and it works fine.
    OPS shows up, but it doesn't dim the audio.
    Carsystems.pl now sell OEM composite cameras and looms, so that's what I will be getting.
    Highline B7's come with BT Premium and MDI, which I will just be removing from the Gateway.
    The Media and Nav screens don't appear in the MFD, but not a deal breaker. Wife's car anyway and she prefers the Spotify interface and Siri for hand free iMessage.
    I will post up how the RVC looks, and I have read reports the composite OEM camera with this RCD330 plus is better than the MK7 Golf R RVC, but that's conjecture at this point in time.
  4. #144
    Jan 2010
    Some questions for people that have done this already or have researched it.
    I have a mk6 R with Dynaudio and RNS510 (with nav and the ****ty Bluetooth connectivity that only lets you answer and hang up the phone).
    The other issue with my unit is the GPS is always on the piss and thinks your about 500m from where you actually are.
    So I am looking for an upgrade and came across the RCD330+ and then of course this thread.
    - does the RCD330 work with OEM reverse camera and sensors?
    - does the RCD330 work with Dynaudio?
    - I assume it's a direct plug and play?
    - I assume GPS is redundant with carplay/android play?
    - can you get a unit that does both android and apple? (Work phone is iPhone and personal is Samsung)
    Thanks heaps!
  5. #145
    Jul 2015
    The prospect of upgrading the RCD310 with crappy bluetooth in my Polo 6R is quite attractive. However I am also looking at getting a Galaxy S8, so I need to try and find a model that has Android Auto, right? Seems only a few have this like this one:
    Buy Products Online from China Wholesalers at Aliexpress.com
  6. #146
    Sep 2017
    Yangon
    Quote Originally Posted by golf2001 View Post
    1. No, if you have RGB back cam. RCD330 works only with composite. You will need additional RGB to composite adaptor.
    2. Some people has done it. I believe you need VAGCOM and VCDS coding.
    3. Yes and No. If you car has Dynaudio or back cam or OPS, this is not easy plug and play. You need VCDS coding.
    4. As far as I know No since this head unit is from China and Android Auto doesn’t work there. But in your case you are using Samsung then still can use MirrorLink.
  7. #147
    Jan 2010
    Thanks Tristan!
    Has anyone seen the one below? Seems like they've hacked it to get Android Auto on the RCD330 as well as CarPlay and MirrorLink.
    Very keen to buy this, but seller doesn't have any reputation from what I can see?
    Quote Originally Posted by cam070 View Post
  8. #148
    Dec 2014
    Monaro, NSW
    Thanks heaps!
    Sounds to me like you just need to get the better OEM Bluetooth module and GPS fixed. When measured against your current setup, I would think getting the RCD330+ would be a retrograde step.
    Daily: 2010 Tiguan TDI | Candy White | Manual | 4MOTION | New York Wheels | Comfort Pack | Tinted Windows | Discover Media | MkVI MFSW | Mk7 Climatronic | RVC | Fog Lights | ECB Nudge Bar | Hella 160 Driving Lights | Rola RBXL135 Cross Bars | To Do: Colour MFD
    Toy: 2008 GTI Pirelli | Sunflower Yellow | 3 Door | DSG | Pirelli Wheels | RNS-510 | 9W7 Bluetooth | RVC | Rear Sensors | Fog Lights | To Do: Mk7 Climatronics, MkVI MFSW, Colour MFD
  9. #149
    Sep 2017
    Yangon
    Thanks Tristan!
    No worries!
    Btw, I found on another forum. This head unit is called RCD340. Check it out here.
    YouTube
  10. #150
    Jan 2010
    Quote Originally Posted by arcadelt View Post
    I wasn't aware you could upgrade the Bluetooth module easily (are you talking about adding a new module (9w7) and VCDS coding)? Also how would I go about getting the GPS fixed?
