If you are installing a discover media that uses address 5f theb you need a newer gateway software but I think 330g uses address 56 radio.
What if you put your rns back in?
Changed back to original can gateway and still the same. If I unchecked 56.Radio from can gateway, there is any error on can gateway.
Now I have no idea why gateway is not talking to Radio if checked in gateway installation list. From other hand, time and temperature are showing correctly on head unit which mean there is communication from gateway to radio. I am very confused.
Do I need canbus decoder?
You need to tick address 56 radio. Not untick it.
Sounds like there is something wrong with the unit if you can't communicate with it.
Most other reports I have read say that the rcd330 install was a 5 minute plug and play job and it just worked.
