Page 13 of 55 FirstFirst ... 3111213141523 ... LastLast
Results 121 to 130 of 548
Thread: Replacing RNS 510 with RCD 330+
  1. #121
    Quote Originally Posted by Tristanmin View Post
    Hi Guys,
    I am new here and nice to meet you all.
    I am also like you guys excited to upgrade this HU and went ahead on my Golf MK6. But now I am facing a problem. My OPS is not showing on screen. I searched numerious forums and tried different coding and upgraded CAN Gateway as well but still no luck. So I hope someone from here can pinpoint my problem.
    - My OPS is retrofitted one which I purchased from AliExpress.
    - When I put reverse gear or press the button, only make beep sound. (The rest function as expected, only visual is not showing on screen)
    - Radio volume is lowered (which mean Radio is communicating with this OPS module?)
    - For wireing, I tapped High/Low to CAN Gateway (I believe this is correct as I am able to access OPS module Address.10 via VCDS)
    - For 12V power, I connected to ACC (Power). Which mean can activate OPS without starting the engine. (Is this should be the right way?)
    - My OPS module is 56D 919 475 A. (Module itself is problem?)
    - When I scan using VCDS, there is a one “Missing message” error. But most people said they also have that error and not effecting the functionality. Some said have to upgrade instrument cluster. (I have no idea)
    So kindly please help me as I spent so much time on this and also invested a lot on this.
    Thanks in advance!
    Check coding on your Park assist module, may need to check a bit for RVC.
  2. #122
    Sep 2017
    Yangon
    Thanks for your support.
    Yes, that is what I did. I coded the park assist module correctly. But still not showing on HU. Anything I should try next?
  3. #123
    My memory ain't what it used to be but I vaguely recall also going into radio/navigation/and or instrumentation modules and ticking certain bits.
    When I first installed a new RNS510 a couple of years ago I couldn't get it to function properly until I manually changed the long code numbers using my Ross Tech cable which I think I was given a web link from the seller after many phone calls.
    I also recall having to reboot the HU by holding certain buttons on face of the HU so it recognizes the changes.
    This may not be of any help whatsoever so ever but you will sort it eventually with persistence.
    Cheers dave
  4. #124
    Post a full autoscan
  5. #125
    Sep 2017
    Yangon
    Quote Originally Posted by weonarok View Post
    Cheers dave
    Thanks for your input Dave. I will definitely check the modules you have mentioned.
  6. #126
    Sep 2017
    Yangon
    Ok. I will be getting genuine VCDS cable on coming Monday. Will post by then. Thanks for your help kamold.
  7. #127
    Sep 2017
    Yangon
    I have received the cable today but surprisingly VCDS is not able to found my RCD330+. I have already enabled 56.Radio and no matter what I did (Unplug battery, reboot RCD), not able to read.
    I believe CAN gateway is already talking with this head unit since temperature and time are synced correctly. Some more when I put reverse gear, radio volumn is lowered automatic. Am I right?
    I really need you guys help Below is my the scan. Thanks!
    PHP Code:
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
    VCDS Version
    17.8.0.1  HEX-V2 CB0.4401.4
    Data version
    20170721 DS276.2
    Chassis Type
    1K-VW36 (7N0)
    Scan01 02 03 08 09 10 15 16 17 19 25 42 44 46 52 56 61 62 72
    VIN
    WVWZZZ1KZDW002641   Mileage43930km-27296miles
    10
    -Park/Steer Assist -- StatusMalfunction 0010
    19
    -CAN Gateway -- StatusMalfunction 0010
    56
    -Radio -- StatusOK 0000
    Address 01Engine (J623-CBZB)       Labels:. 03F-906-070-CBZ.clb
      Part No SW
    03F 906 070 JK    HW03F 907 309 S
      Component
    SIMOS10.13AH10 2682
      Revision
    : --H10---    Serial number00000000000000
      Coding
    002500B6232401080000
      Shop
    #: WSC 01357 011 00200
    ASAM DatasetEV_ECM12TFS02103F906070JK 004005
      ROD
    EV_ECM12TFS021.rod
      VCID
    74B2D4271E3FC6574F2-8020
    No fault code found
    Readiness0110 0101
    Address 02Auto Trans        Labels0AM-927-769.clb
      Part No SW
    0AM 300 060 D    HW0AM 927 769 D
      Component
    GSG DSG AG7     431 3656
      Revision
    00043014    Serial numberCU501205055322
      Coding
    0000020
      Shop
    #: WSC 73360 981 89128
    VCID2B000F5B8F01D9AFDE8-807E
    No fault code found
    Address 03ABS Brakes (J104)       Labels:. 1K0-907-379-60EC1F.clb
      Part No SW
    1K0 907 379 BL    HW1K0 907 379 BL
      Component
    ESP MK60EC1   H31 0152
      Revision
    00H31001
      Coding
    133B400D212200FCC81102E8841A0090310000
      Shop
    VCID7DA4F1032DF5871F30C-8028
    No fault code found
    Address 08: Auto HVAC (J301)       Labels:| 3C8-907-336.clb
      Part No SW
    7N0 907 426 BG    HW7N0 907 426 BG
      Component
    AC Manuell    H20 0505
      Revision
    : 00001018
    Coding0010004003
      Shop
    ASAM DatasetEV_ACManueBHBVW36X A01010
      ROD
    EV_ACManueBHBVW36X_VW36.rod
      VCID
    7AAEFA1F3C5BB02715E-802E
    No fault code found
    Address 09: CentElect. (J519)       Labels:. 1K0-937-08x-09.clb
      Part No SW
    1K0 937 084 J    HW1K0 937 084 J
      Component
    BCM PQ35  B   111 0709
    RevisionAB111709
      Coding
    46180A38E8251AC0408800C0340000244F510288436D8960648087200041
      Shop
    VCID3534292355459F5FB8C-8060
      Subsystem 1
    Part No5K2 955 119
      Component
    Wischer 14051  26  0512
      Coding
    : 009795
    Subsystem 2 Part No1K0 955 559 AH  Labels1K0-955-559-AG.CLB
      Component
    RLS 160512 05  54  0403
      Coding
    0F30AD
    No fault code found
    Address 10Park/Steer Assist (J446)       Labels:| 1Q0-919-475.clb
      Part No SW
    56D 919 475 A    HW56D 919 475
      Component
    PARKHILFE 8K  H02 0006
      Revision
    : --------    Serial number35811401500962
      Coding
    300101
      Shop
    #: WSC 12345 123 12345
    ASAM DatasetEV_EPHVA18VW4110000 001007
      ROD
    EV_EPHVA18VW4110000.rod
      VCID
    3330173B5BB1816F968-8066
    1 Fault Found
    12658720 Databus
             U1121 00
    [009] - Missing Message
             Confirmed
    Tested Since Memory Clear
                Freeze Frame
    Fault Status00000001
                       Fault Priority
    6
                       Fault Frequency
    1
                       Reset counter
    168
                       Mileage
    43938 km
                       Date
    2017.09.24
                       Time
    11:43:39
    Address 15Airbags (J234)       Labels:| 5K0-959-655.clb
      Part No SW
    5C0 959 655 D    HW5C0 959 655 D
      Component
    AirbagVW10G   013 0613
      Serial number
    003G7RA1KCJT
      Coding
    00004431
      Shop
    ASAM DatasetEV_AirbaVW10SMEVW360 A01014
      ROD
    EV_AirbaVW10SMEVW360.rod
      VCID
      Crash sensor
    for side airbagdriver side
    Subsystem 1 Part No SW5K0 959 354     HW5K0 959 354
      Component
    S.Sens.Fahr.V  H02 ----
    Serial number3572MSME1C215166ZZZR
      Crash sensor
    for side airbagfront passenger side
    Subsystem 2 Part No SW5K0 959 354     HW5K0 959 354
      Component
    S.Sens.Beif.V  H02 ----
    Serial number3582MSME6F085566ZZZ2
      Crash sensor
    for side airbagreardriver side
    ComponentS.Sens.Fahr.H  --- ----
    Serial number3512QSME782E1142ZZZU
      Crash sensor
    for side airbagrearpassenger side
    ComponentS.Sens.Beif.H  --- ----
    Serial number3522QSME6405114CZZZP
    No fault code found
    Address 16Steering wheel (J527)       Labels:| 5K0-953-569.clb
      Part No SW
    5K0 953 507 AJ    HW5K0 953 549 B
      Component
    Lenks.Modul   008 0090
    Revision: --------    Serial numberWHRPIÄiÄHHHHS
      Coding
    5880100000
      Shop
    #: WSC 00000 000 00000
    ASAM DatasetEV_SMLSNGKUDS A05001
      ROD
    EV_SMLSNGKUDS_A05.rod
      VCID
    78AAE0170257A23763A-802C
    No fault code found
    Address 17Instruments (J285)       Labels:| 5K0-920-xxx-17.clb
      Part No SW
    5K0 920 873     HW5K0 920 873
      Component
    KOMBI         H05 0705
      Serial number
    00000000000000
      Coding
    570B00
      Shop
    ASAM DatasetEV_Kombi_UDS_VDD_RM09 A04716
      ROD
    EV_Kombi_UDS_VDD_RM09_A04_VW32.rod
      VCID
    6D84C1437D15179F80C-8038
    No fault code found
    Address 19CAN Gateway (J533)       Labels:. 7N0-907-530-V2.clb
      Part No SW
    7N0 907 530 AH    HW7N0 907 530 AH
      Component
    J533  Gateway H50 1634
      Revision
    :   H50       Serial number26031400F13662
      Coding
    350003
      Shop
    VCID76B6EE2F08C3D447716-8022
    1 Fault Found
    01305 Databus for Infotainment
               004
    No Signal/Communication
                Freeze Frame
    Fault Status01100100
                       Fault Priority
    1
                       Fault Frequency
    1
                       Reset counter
    168
                       Mileage
    43938 km
                       Time Indication
    0
                       Date
    2017.09.24
                       Time
    11:43:38
    Address 25Immobilizer (J334)       Labels:| 5K0-920-xxx-25.clb
      Part No SW
    5K0 953 234     HW5K0 953 234
      Component
    IMMO          H05 0705
      Serial number
    00000000000000
      Coding
    000000
      Shop
    ASAM DatasetEV_Immo_UDS_VDD_RM09 A03709
      ROD
    EV_Immo_UDS_VDD_RM09_VW21.rod
      VCID
    6A8ECA5F4CFB00A7E5E-803E
    No fault code found
    Address 42Door ElectDriver        Labels:. 1K0-959-701-MAX3.clb
      Part No SW
    5K0 959 701 J    HW5K0 959 701 J
      Component
    Tuer-SG         009 2106
      Coding
    : 0135862
    Shop #: WSC 14898 001 1048576
    VCID392C2513755D7B3F5C4-806C
    No fault code found
    Address 44Steering Assist        Labels1K0-909-14x-GEN3.clb
      Part No
    1K0 909 144 P
      Component
    EPS_ZFLS Kl68     3305
      Revision
    00H22000
      Shop
    VCID3728232B43496D4FAA0-8062
    No fault code found
    Address 52Door ElectPass.        Labels:. 1K0-959-702-MAX3.clb
      Part No SW
    5K0 959 702 C    HW5K0 959 702 C
      Component
    Tuer-SG         009 2120
      Coding
    : 0136118
    Shop #: WSC 01357 011 00200
    VCID3330173B5731816F968-8066
    No fault code found
    Address 56Radio
    Cannot be reached
    Address 61Battery Regul. (J840)       Labels:. 1K0-907-534.clb
      Part No SW
    7N0 907 534     HW7N0 907 530 AH
      Component
    Batt.regelung H50 1634
      Serial number
    26031400F13662
      Coding
    F300185A
      Shop
    VCID71BCDD3361ADF37FA44-8024
      Subsystem 1
    Part No SW1K0 915 181 H    HW1K0 915 181 A
      Component
    J367-BDM  H07 0180
    Serial number: 00000000008900316113
    No fault code found.
    Address 62DoorRear Left        Labels:. 1K0-959-703-GEN3.clb
      Part No SW
    5K0 959 703 D    HW5K0 959 703 D
      Component
    Tuer-SG         007 2101
      Coding
    0131216
      Shop
    #: WSC 01357 011 1012552
    VCID3534292359459F5FB8C-8060
    No fault code found
    Address 72DoorRear Right        Labels:. 1K0-959-704-GEN3.clb
      Part No SW
    5K0 959 704 D    HW5K0 959 704 D
      Component
    Tuer-SG         007 2101
      Coding
    0131216
      Shop
    VCID36362E2F44439447B16-8062
    No fault code found
    End----(Elapsed Time01:03VBatt start/end11.9V/11.8VVIgn 11.9V)-----
  8. #128
    You can see from your autoscan that your canbus gateway has a fault - it cannot see anything on the infotainment bus.
    The radio is accessed on this bus. So until you fix this issue you will not be able to get the head unit to see the CAN signal that the car is in reverse and turn on the camera.
    You need to first look at the cabling - is there a quadlock adapter harness that the radio plugs into?
  9. #129
    Sep 2017
    Yangon
    Yes, there is a quadlock directly plugged into head unit. Should I try swapping can high and low from there?
  10. #130
    I have no idea of the history. Normally you should not have to be swapping pins around.
    But you need to do whatever you can to restore communication to the infotainment bus from the CAN gateway.
