Is there something wrong with the DVD drive?
Can you try loading the map directly from the DVD?
Hi Everybody,
I am new on the platform. I would like to mention about my problem what i am having currently.
I had RCD 310 in my Jetta 2013 TDI, I changed it to RNS 510 (without VCDS coding etc.)
then i turned on the device everything was good except navi. because navi was showing West Eu map. Therefore i wanted to change it to V13 East EU map.
Then I prepared SD cart with the v13 map and DVD which is for copy files from SD to HDD.
however, after that i uploaded the map by following procedures in here "https://paulroberts69.wordpress.com/2015/10/01/upgrading-firmware-and-maps-on-vw-rns-510-satnav/"
the map info showing "-". that means although everything was performed ok, the even current map has been deleted.
I appreciate for your help .
Not having a GPS antenna connected will not prevent the maps from loading and displaying correctly.
It just won't show the correct position on the map.
When i put dvd, the map is showing copying to HDD. after that is done, the device restart itself. then i check the version info, it shows "-" for map info. and when i pressed nav button, it says "please insert map dvd".
Yes, HDD have around 100 pcs mp3. i check HDD deleting couple mp3. but i did not try to copy.
5238 is currently seen in version info.
Do you have a different maps DVD you can try?
