Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Replacing RCD 310 to RNS 510
    Nov 2017
    Turkey
    I don't have any other DVD for different maps because i dont know which version of map is compatible with the device. i dont want to do something wrong. shoud i try it?
    All maps are compatible with all sw versions, they are just more up to date map contents.
    So you can load an earlier map to test.
    Then load the newer map which will replace it.
    Nov 2017
    Turkey
    I would like to found V10 version map is it ok?
    let me try to load it via DVD. then i let you know about the result.
    Thanks
    Quote Originally Posted by Salazar View Post
    Thanks
    Sounds good
    Nov 2017
    Turkey
    Hi,
    It worked, when i tried to load v9 map by DVD. but there another problem occurred. the device think it is in Germany because when i try to use it, shows Germany map. but i am living in Turkey .
    I checked GPS status, there no seen GPS signal and satellite. is it related GPS antenna? because i did not receive my GPS antenna order yet.
    Hi,
    Yes.
    Once you get a GPS antenna and it located you it will show the correct location.
