Results 1 to 10 of 16
Thread: Replacing RCD 310 to RNS 510
    Nov 2017
    Turkey
    Hi Everybody,
    I am new on the platform. I would like to mention about my problem what i am having currently.
    I had RCD 310 in my Jetta 2013 TDI, I changed it to RNS 510 (without VCDS coding etc.)
    then i turned on the device everything was good except navi. because navi was showing West Eu map. Therefore i wanted to change it to V13 East EU map.
    Then I prepared SD cart with the v13 map and DVD which is for copy files from SD to HDD.
    however, after that i uploaded the map by following procedures in here "https://paulroberts69.wordpress.com/2015/10/01/upgrading-firmware-and-maps-on-vw-rns-510-satnav/"
    the map info showing "-". that means although everything was performed ok, the even current map has been deleted.
    I appreciate for your help .
    Is there something wrong with the DVD drive?
    Can you try loading the map directly from the DVD?
    Nov 2017
    Turkey
    No i did not do it yet. onoe more thing there is no GPS antenna (i think it should not affect the head right?)
    Thanks
    Not having a GPS antenna connected will not prevent the maps from loading and displaying correctly.
    It just won't show the correct position on the map.
    Nov 2017
    Turkey
    When i put dvd, the map is showing copying to HDD. after that is done, the device restart itself. then i check the version info, it shows "-" for map info. and when i pressed nav button, it says "please insert map dvd".
    Quote Originally Posted by Salazar View Post
    Might be a problem with the HDD.
    Can you copy music to it?
    Does it have a HDD?
    Early versions did not have one at all, nav comes from DVD
    Nov 2017
    Turkey
    Yes, HDD have around 100 pcs mp3. i check HDD deleting couple mp3. but i did not try to copy.
    What firmware version is installed?
    Nov 2017
    Turkey
    5238 is currently seen in version info.
    Do you have a different maps DVD you can try?
