Results 1 to 10 of 17
Thread: Removing Eurovox
    Apr 2008
    Bundoora Victoria
    Removing Eurovox
    Hi all
    I'm new to VW's so you'll have to excuse me if I ask some ridiculous questions. I've just bought a 2001 Bora and want to replace the original Eurovox 4680 with something better. I've had a go with wires into the 4 holes on the sideof the front but it doesn't seem to want to come out.
    Is that the way to remove it or is there some other sneaky way like a rear bolt?
    Thanks in advance
    doc
    Feb 2007
    Central Coast, NSW
    To get mine out properly I had to:
    From the left side, take the black side cover off ( you will see it when you open the door )
    Take out the glove box ( 6 screws from memory )
    That will expose 2 screws for the main frame.
    Now from the other side:
    Take off the same black cover ( the fuses are under there )
    Take off the first cover and bottom covers
    Take off the second cover and that will expose the 2 screws on the right.
    Under the 4 screws and the middle console will come out. Ill see if I can find the link from vwvortex, I think there are piccies on there.
    Bora has gone ;( Custom sub box and beige floor mats to suit for sale.
    Apr 2008
    Bundoora Victoria
    Gee that was quick. Thanks. Seems like a lot of work just to get a stereo out. I'd appreciate the pictures if you can locate them.
    May 2007
    Go get yourself the proper removal tools; VW / eBay etc.
    Then it will come straight out.
    Failing that, go to autObarn and they will remove it for you...
    Apr 2008
    Bundoora Victoria
    Thanks 126. Will do.
    Feb 2007
    Central Coast, NSW
    Yeah ill try and find all my piccies. I think I actually took them all step by step. The only other thing you can try is getting those thin metal removal tools and take it out but I think it was bolted in at the rear. I probably just did it the hard way but it worked
    this is what you need to get the radio out without going to the hassle of removing other panels...
    Apr 2008
    Bundoora Victoria
    Thanks icacha. I made some similar out of coat hanger wire but I've got the feeling they were too short. I'll have another go tomorrow.
    Thanks all for the help.
    Feb 2007
    Central Coast, NSW
    Sorry dude I can not remember about any bolts and stuff but I know when I took all the panels out it was still really hard to get out. Anywho, the guys in the UK ( vwvortex ) reckon that taking the panels out is the way to go. I gave pulling it out 10mins ( using the metal release brackets that Pioneer etc give you ) and no love so I did the following ( see piccies ).
    Only took a little over an hour all up. It's a pain in the bum doing it that way but I either had a crap day or you just can not pull it out. You will need a screwdriver with H25 heads.
    I would definately see if you can pull it out though!
    Apr 2008
    Bundoora Victoria
    Thanks all for the assistance. I'll see how I go.
