Results 1 to 10 of 17
Thread: Recommend me an AV input module for my RNS510
    Hi,
    Looking to buy myself an AV input module to allow me to watch video in (and sound) on my 510.
    I'd appreciate some recommendations from actual users
    MY18 GOLF 110TSI I HIGHLINE I Indium I Panoramic Sunroof I DAP I IP
    MY18 TIGUAN 162TSI I R-LINE I Ruby I DAP I IP
    Jun 2012
    Portugal
    Hi
    I am trying to do this. The problem is activate the AV input in RNS510, all the others is easy. The RNS510 has an RGB input so if you have a source with RGB output is a direct connection (I have an little home DVBT receiver that has RGB output so I only need to change the power input).
    I try to change the RNS510 firmware to put the AV flag always high and not vw tuner dependent but I need the firmware source.
    Other possibility is writing to can and say "I am the tv tuner and I am here", now I try to decode the can message...
    An excellent New Year
    Mar 2009
    UMG Brisbane
    Have a read on the "video in motion" hack for the RNS. Might be what you are after, can play limited formats from SD Card or from the HDD. That's all I know about it, but there is more info on here (might be under VIM too)
    Al..
    2013 MY13.5 Passat V6 Highline Wagon. Watch this space
    GONE:2017 MY18 Skoda RS169 Wagon w/ Tech & Lux, 2007 VW MKV Golf GTi
    Apr 2010
    AFAIK the RNS510 can't play video files from HDD or SD card. Only DVD. Video in Motion allows the video to keep playing when you speed is below 255kph instead of the default setting of ~7kph.
    There are a bunch of AV devices for the RNS510 on eBay if you search. It uses the same connection as the reversing camera, so you can't have both. I have a camera so I've never bothered with this.
    Pacific Paradise QLD
    Quote Originally Posted by 99_FGT View Post
    Al..
    His sig says he has VIM enabled so maybe it doesnt do what the wants
    What might be the solution is to fit a switchbox in the RVC video circuit with several inputs into it and make the feed switchable similar to what I did with two rearview cameras. I realise the VW setup is a bit more complicated but could be worth a try
    Nov 2012
    clalyton,melbourne
    Nov 2012
    clalyton,melbourne
    Yes should do the trick However I was thinking of a simpler cheaper solution like about $20 from Jaycar without all the electronic controls.
    Whatever you want to pay I guess
    Adelaide hills, SA
