I got one last week, enjoying the unit. Here is my post from a different forum on it.
I am also in Brisbane send me a PM if you want any extra info.
Only other Problem I have had with the NC-2010 is that it likes to read USBor SDHC data
in the order it was written to the memory unit. This can be easily fixed by downloading DriveSort
which reorders correctly and saves everything for you.
_________
This Head unit puts out better sound than the RNS 510 and is much easier to use. Plus it looks just AWESOME!!
Blue tooth unit is parrot and the quality is excellent, includes external microphone.
It has movies on the move on by default which is a positive for me but a negative for some.
The unit has a MDI like device for Iphones, Thumb Drives & has a 3.5mm audio jack in.
I used a sandisk 32GB SDHC card for songs and the load time with about 18gb of data on the card in about 3-4 seconds a file has began playing. Alot of the cheap Chinese units can take 1-2 minutes to start as they like to scan all folder contents before starting some refer to this as LAG. I have also tested 32GB Sandisk Thumb drive no issues and once again minimal lag compared to my old cheap china Head Unit.
The Blue tooth unit downloads a copy of your phonebook onto the Head unit allowing you full access to not only contacts but also call logs. (Tested Iphone 3GS, Samsung Galaxy S2 & Iphone 4). I take a lot of calls on the road so the phone book is needed so I can see just who is ringing.
Also BT screen allows you to scroll thru and play movies and Sound files directly from the connected device via a menu button on the screen. (Tested Iphone 4)
Retrofitting into my existing Reverse Camera System was a simple matter of connecting a RCA Plug.
SatNav is powered by Igo maps and you have to register online to update. I have registered but have not yet run the upgrade utility on the head unit (you down load this and run it via thumb drive attached to the HU). Map date on the system is Late June 2011 and I'd imagine the firmware should be up to date as well.
Took it for a run yesterday down south to an area that has had alot of roadwork done in the last 12 months. All new flyovers on the Freeway were marked in the correct location. Overall SatNav ran very well no issues apart from the Traffic Module not being licensed.
With VAGCOM VCDS reprogramming it is possible to get the Zenec Headunit to output to the Dash Readout. As my Trendline does not have the correct module extended dash readout is not available. Hopefully when the MF steering Wheel comes out t will be retrofittable with a new module.
Overall a great unit and while the RRP is around $2200.00 it is well worth buying rather than a RNS 510 + VW Premium Blue Tooth + VW MDI which supports less playable formats than the Zenec. I got mine installed for $2k which felt about right.
