I had a look at the website. I believe they are 2ohm speakers. It is rather confusing the way they advertise their products.
You can run 2 Ohm speakers off a factory head unit. However I must warn you that it will cause the amplifier in the head unit to work harder. Which means the head unit will get hotter. This all depends on how loud you crank up the volume. If you like your music loud then dont be surprised if the head unit fails after a while.
