Hi all,
Been lurking around here for a while and I've searched for this problem but can't seem to find any solutions and hoping someone might be able to help. I have purchased an Aussie RCD510 from E Bay (one from someone upgrading to Sat Nav). Fitted it today with instructions found on here and just about everything works great except for viewing the phone book from a bluetooth connected phone. The phone book displays but the info within seems jumbled, the numbers behind each contact appear slightly messed up (sometimes with a combination of two contacts in one) and when I try to dial a number via the touchscreen I get the message "dial up failed". I've tried clearing the bluetooth connection and establishing it again but it's still the same. I've tried two different phones and with both of them the phone book issue is there. I can access dialled numbers, missed calls, etc and dial from there fine, I only get "dial up failed" when dialling from the phone book. I can however go into the MFD via the steering wheel controls and access the phone book okay from here and this works, but I would obviously much rather to be able to use the touchscreen. Maybe the RCD510 is conflicted with the MFD as it thinks there's still a RCD310 there??? Don't know.
I'm not sure of the bluetooth version but the car is a MY12 Golf Comfortline.
Thanks for a great site and any help would be much appreciated.
