Results 1 to 10 of 20
Thread: RCD510 SD Card questions
    Jul 2007
    Canberra
    Hey Guys,
    About to fill up an SD card for the RCD510 and have a couple of questions:
    What type of files did you load the songs on the card as? .wav .mp3 etc?
    Do the songs or artists need to be in a certain order etc.?
    Did you put play lists in?
    Simon
    Forever blowing bubbles.
    Mar 2009
    UMG Brisbane
    MP3, not sure if they will play WAV files. Won't play the ipod file format (M4a is it?)
    I honestly haven't had a lot of luck with the SD card, as I tried a stacked and a flat folder structure, and both proved very slow to load on startup.
    I have heard that playlists are the way to go, with playlists at root level, and one folder at root level with all the music in it. Never got around to trying it (I should try again though). This was all with a class10 SDHC as well...
    Al..
    2013 MY13.5 Passat V6 Highline Wagon. Watch this space
    GONE:2017 MY18 Skoda RS169 Wagon w/ Tech & Lux, 2007 VW MKV Golf GTi
    Mar 2008
    Sunshine Coast
    Had no problem at all with SD cards and I carry a dozen or so in the car as replacements for CDs
    8VSS2L/16 E9E9 XG MP SPP1 4ZD 6XK CSC5P with an extra free 10kW
    Mar 2009
    UMG Brisbane
    Quote Originally Posted by Candyman View Post
    So they load fast enough then? I'm talking 20-30 seconds EVERY time I start the car. Can be halfway up the road and all of a sudden music started.
    What folder structure and file format are you using, and what size cards?
    Mar 2008
    Sunshine Coast
    They load instantly, no delay
    Thrown in as single mp3s at root folder, as grouped files in sub folders
    Mix of old cards (16mb to 2gb) to current high speed cards (2-4gb)
    I used up all those random cards that come with cameras etc
    All perform the same
    Note, all mine are ripped at 256 max
    I also have a Class 10 Extreme IV Sandisk SD and it's pretty slow. I have tracks in the ROOT folder and folders in ROOT for albums. What do you guys mean by playlists? .pls file?
    MKV GTI Pirelli
    Mar 2008
    Canning Vale, WA
    I use an 8gb class 4 and only have a slight delay on tracks with a high bit rate.
    I've got about 8 folders in there, but no subfolders below that level.
    All tracks play and load instantly except the ones at a high bit rate, which take maybe 3 seconds.
    T Go
    MY11.5 Golf GTI | Bluefin Stage 2 | Pipercross Stage 2 Intake Pipe | AFE Pro 5R Filter | SPM Downpipe | VWR Sport Springs | H&R 22mm RSB | R LED Tail Lights
    Jul 2007
    Canberra
    Thanks guys all good info!
    Apr 2012
    I have been having the same issue with my SD card reader. I'm getting SD error cannot read.
    Is there a specific format because atm its currently formatted as exFAT
    GOLF GTI MY11 ADIDAS Candy White, Sunroof
    GOLF GTI 40th ED, White with Sunroof
    Needs to be FAT32 formatted.
