Old thread I know, but just got a 16GB SDHC (Class 10) card for my RCD510, loaded it up with about 6GB of music, problem is when the car starts it takes ages to start up.
I have set it up with 6 high level folders
A-H, I-O, Q-Z, JJJ Live, JJJ Like a Version, JJJ Hottest 100 CD
Below that are either album folders (for the JJJ folders), or artist, then album folders - max depth 4 folders. Did this to make it easy for me to find stuff.
I have read conflicting reports on what is the best structure to have -a flat directory structure, or a tree'd structure.
Took about 1min to load up when I first put the card in, which I expected, but then about the same when I restarted the car (after stopping to go to the ATM - about 2 min).
Has anyone played with this to see how it behaves and what is the best structure to have? Had also seen the playlist trick as well (put all your playlists up top, and use these to look into the folders) - is this any better? I thought the card would only index once and then be a fast startup after that.
Al..
2013 MY13.5 Passat V6 Highline Wagon. Watch this space
GONE:2017 MY18 Skoda RS169 Wagon w/ Tech & Lux, 2007 VW MKV Golf GTi
