Bamazonke:
Thanks for the input I'll probably message dana over at vwvortex, and I'll probably disable the sat radio as it is something I dont use and see what happens.
Roscoe1974: If you can get a scan of your vcds, you think you can find out if your "media player 3" option cannot be found? I think this is the MDI in vcds and it looks like it isn't communicating
This is what I get on my autoscan with the rcd510
With the RCD 310:Address 2E: Media Player 3
Cannot be reached
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 D HW: 5N0 035 342 D
Component: SG EXT.PLAYER H13 0150
Revision: A1001003 Serial number: 7669270753
Coding: 010000
Shop #: WSC 01357 011 00200
VCID: 287121835B700B58495
