Results 1 to 10 of 14
Thread: RCD510 MDi Help?
    Jan 2011
    RCD510 MDi Help?
    Hi all,
    Purchased an RCD510 (I believe genuine, reconditioned) from a regular seller of such on eBay, and have installed it into the Tig with no hassles at all (extremely happy with how easy it was!).
    Only one little problem I'm having - the seller supplied a USB cable to connect iPod/iPhone etc. and I can (and do) use that, however...
    I have a factory-installed MDi, and the RCD510 is not 'talking' to the MDi and will not recognise it. Additionally, the USB connection continues to charge the iPod even when the car is switched off which concerns me re. flat battery issues (for the car - don't care about the iPod)
    I contacted the seller and he stated 'Unfortunately, you gotta programme the unit to enable the MDI interface of it....'
    I've got no problem with the seller - he's been great - but I don't want to have to take the unit back out, send it interstate and get him to reprogram it then send it back again.
    Is anybody aware if this 'reprogramming' can be done via VCDS/VagCom? And can the constant charging of the iPod when the car is off be amended so it doesn't occur? If so, is there anybody around the Brisbane area who might be able to help me with this?
    MY2011 Tiguan 103 TDi 7spd-DSG, Deep Black Pearl Effect, Comfy Pack, MDi, OEM Tow Package, Tint - LOVE this car!
    May 2012
    MY16 Candy white Octavia VRS Wagon, sunroof, 19" black pack, tech pack, comfort pack, auto tail gate
    MY12.5 Polo 6R GTI
    Dec 2008
    Sydney/Canberra
    The MDI needs the dedicated iPod cable for it to work. It will display a connection error on your Apple device.
    i.e. this: VW RCD510 AMI AUDI RNS510 MEDIA-IN MDI Interface Adapter Cable for iPod iPhone | eBay
    You can code the CAN-bus gateway to say that it's got the RCD510 instead of the 310, but as far as I'm concerned, it makes little to no difference in the grand scheme of things.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Jan 2011
    Quote Originally Posted by Umai Naa!! View Post
    I do have the iPod-specific MDi Cable - like a schmuck, I purchased it via VW when I ordered the car (you live & learn from these mistakes...hindsight is wonderful thing... ) however from what the RCD510 seller says, it's (the lack of connectivity from MDi to RCD510) a programming issue in the RCD itself. Just wanted to have it all neat & tidy, and how it was functioning with my RCD310, rather than dangling a USB cable into my glovebox, and would like to see the Track Info etc on the MFD again. I'll check out the VagCom-users link though (thanks lunchboxGTI). Appreciate the help guys.
    I did this retrofit a while back and didn't have an issue. No recoding required in my case. MDI worked when I connected up RCD510 - no reprogramming required in my case so I guess I'm lucky.
    Dec 2012
    Tampa, FL, USA
    I guess this is the same issue I am having with the Chinese RCD510 on my 2011 GTI, the RCD 510 also came with the supplied USB cable but I did not connect it.
    Seems like the MDI isn't connected or seeing it. I posted this over VWVortex, if you can get a vcds scan of what yours is doing it, I'd like to see if you are receiving the same codes as me. From what it seems, I cannot establish connection with the media player, and I assume this is the MDI module. I've tried what looks like selecting it, but it looks like it wont let me in VCDS. Over at golfmk6 in another thread another user got a chinese rcd510 and has a picture showing the media in and MDI working.
    VWVortex.com - Installed Chinese market RCD 510 onto a 2011 GTI, MDI doesnt work and have fault codes
    I know mine was a genuine RCD510 as it came from a VW dealer who pulled it from a new Amorak - upgrade to SatNav system prior to delivery.
    I suspect that there's a few aftermarket Chinese copies floating around the place with software/hardware that's not fully supporting all the functions.
    Anyway if it's some use to you guys here's the VCDS scan of the useful bits:
    Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
    Part No SW: 5N0 035 342 D HW: 5N0 035 342 D
    Component: SG EXT.PLAYER H13 0150
    Revision: A1001003 Serial number: 7669593423
    Coding: 010000
    Shop #: WSC 01324 020 00200
    VCID: 285586C55BE52058495
    No fault code found.
    Address 56: Radio (J0503) Labels: 5M0-035-1xx-56.clb
    Part No SW: 5K0 035 190 A HW: 5K0 035 190 A
    Component: Radio RCD510 050 0207
    Revision: 00000001 Serial number: VWZ1Z3L1636560
    Coding: 00000440020016
    Shop #: WSC 07456 790 50316
    VCID: 234F91E922C3C3001C7
    Address 77: Telephone (J412) Labels: 7P6-035-730.clb
    Part No SW: 7P6 035 730 F HW: 7P6 035 730 F
    Component: TELEFON H09 2730
    Revision: 1B001001 Serial number: 00007662423196
    Coding: 0A00000000010110
    Shop #: WSC 12345 123 12345
    ASAM Dataset: EV_UHVNA A01015
    ROD: EV_UHVNA_VW36.rod
    VCID: 356B5FB194574DB0C23
    End ---------------------------------------------------------------------
    Dec 2012
    Tampa, FL, USA
    I wonder if it is headunit related and there are several versions of the Chinese rcd 510, I am thinking it is a headunit issue after messing with VCDS. I am currently talking to my seller also about the same issue and have shown him the pictures of both headunits and waiting for his response
    By any chance can you get pictures of both headunits the back? I have a feeling you have the same RCD 510 as me with the extra USB connector in the back.
    This is what mine looks like.
    Picture of the Chinese RCD 510
    Picture of the US RCD 310 that came with my GTI
    My MDI and Aux
    Well it looks like I might be lucky (or maybe I just haven't hit a compatibility issue), however have just googled "RCD510 mdi problem" and there's heaps of hits on various forums about this issue.
    Suggest you go hunting and see what you can dig up.
    I only use an external hard drive run through the USB connector on my MDI and this works fine. I also have an iphone connector cable but I don't use this - my wife has an iphone but haven't heard any issues from her.
    Jan 2011
    [QUOTE=aw614;896585]I wonder if it is headunit related and there are several versions of the Chinese rcd 510, I am thinking it is a headunit issue after messing with VCDS. I am currently talking to my seller also about the same issue and have shown him the pictures of both headunits and waiting for his response
    My MDI and Aux
    Well, yep - it looks as though I have the Chinese version - it looks the same as your first (top) pic. I don't have an issue with that - at the price I paid it's totally acceptable! My MDi is in the centre console of the Tiguan (similar to how yours in the GTI is). Am still waiting to hear from the seller re. whether it can be done via VCDS etc. or if I would need to send the whole unit back for 'reprogramming' as he put it.
    Tigger, thanks for the VCDS tips - if I can go down this route to sort it, it will definitely be handy, and will do some scouting around in the meantime. Happy New Year to all )
