Results 1 to 10 of 17
Thread: RCD510 installed on 08 R32, cant get my bluetooth to work again???
    Mar 2010
    hey guys, i recently just installed my RCD510 on my 08 R32 which already had the factory bluetooth which ran from my old RCD300. Im basically unable to find the setting to turn the bluetooth on on the system itself. Im trying to connect my Blackberry and it just cant seem to find anything when it searches for it?
    Ive looked on the net but i am struggling to find any sort of help on this. Any ideas?
    Tim
    09 MKV R32> Haldex 2> ECS Tuning Delete> Cupra R Lip> Blacked Out> Gallardo Black Wheels> Tow Hook> Black Badging>RCD510
    May 2011
    Gold Coast
    I'm not 100% certain but I think the rns510 uses a different bluetooth kit to the rcd300. Can find out for you tomorrow at work when I query some of the lads. If it is compatible it's more then likely going to be re-coded at a dealer
    Mar 2010
    Do you mean the RCD510 haha. i was told it was completely compatible with my current bluetooth system......so its a recoding issue, i guess vagcom is the answer?
    Jul 2010
    I think it depends on which bluetooth module you have (Volk-l, 9w2, 9w3 etc). With my module (Volk L), there isn't any settings in the RCD 510 to enable the bluetooth.
    I installed my bluetooth to my RCD510 a couple of days ago and it wouldn't work (can't find the VW UHV) until it was coded up properly.
    Are you able to scan for fault codes?
    2008 Passat 3.2 Wagon |
    2002 A3 1.8T | APR Stage 1| APR Downpipe | APR dogbone | Diesel Geek Shifter | TT pedals | Forge DV | Saikou Michi OCC | NewSouth Boost Gauge | AVUS Rims | Whiteline Rear Swaybar & ALK | N75J | BMC CDA | APR TIP & TB Hose |
    Mar 2010
    Yea, i was just playing around with it then and read the manual and there should be a telephone option in the menu settings but it is not showing up. Im also able to enable the bluetooth streaming as an option but it just cant find it. I managed to connect to egotalk on my phone but still it doesnt register.
    I dont actually have a way to search for fault codes?? How did you code it up properly?
    Jul 2010
    Yeah you can enable "BT audio" in the settings menu but its greyed out i guess.
    i coded it up following the instructions (3x hex values) but that's for Volk L. If you have 9w3 or higher then it's more settings.
    Does the bt have voice control and/or address book on your MFD?
    Where abouts are you? many people here have VAGCOM and can scan/code for you. I'm in Chadstone/Mulgrave area and can help if you're nearby.
    Mar 2010
    Ohhh that would be great mate im just 10 mins down the road in canterbury on canterbury rd. If you could give me a hand that would be great! When is a good time?
    It just seems to be that its connecting but its not engaging from the bluetooth to the RCD510.....im fairly new to all this stuff, so still learning as i go.
    Jul 2010
    You have PM
    Posted using Tapatalk
    Mar 2010
    I have an EGOTAlK system and im thinking that this may not be a kit that will work with the RCD 510??
    http://www.vwwatercooled.org.au/f15/...lem-34212.html
    I just read through this and according to some of the posts the EGO TALK is not a genuine vw product and they went bust. Looks like i might have to get a new bluetooth kit.......
    May 2011
    Gold Coast
    You need to recode the headunit to know that it has bluetooth
