Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: RCD510 + bluetooth phonebook functions
    I've just removed the original RCD310 and replaced with RCD510 in a 2011 Tiguan (white MFD). I didn't change the Bluetooth kit - stayed as original (1K8 051 730 D).
    Everything works as it previously did (phone/volume buttons on steering wheel), however I was hoping that the phonebook functionality would work but I'm guessing I may have to upgrade to 9w7 bluetooth to get this going.
    I tried disconnecting the bluetooth connection, deleting all connections out of the car and then repairing but this didn't suck out the phone book.
    The only thing that happens now is if I press the "phone" button on the RCD510 then it mutes the radio.
    Before I go buying a 9w7 (which I think I may have to) does anyone know if there are VCDS functions that have to be enabled to get the phonebook working?
    Thanks.
    Jan 2012
    Carnegie
    What are you planning to do with your RCD310?
    Sorry I can't help with your question.
    I've got an RCD510 with 9W7, red MFD. Phone book works but steering wheels button just mutes.
    2006 B6 Passat Wagon 2.0 TDI
    RCD510, MDI, 9w7 bluetooth, Footwell lights, Door warning lights
    VAGCOM cable owner
    Mar 2009
    UMG Brisbane
    There are definitely options in VCDS, but nothing that you should need to use. If you go into the settings menu on the RCD510 do you have a "telephone" option? Enables bluetooth in Media-in and phone book functions IIRC
    Al..
    2013 MY13.5 Passat V6 Highline Wagon. Watch this space
    GONE:2017 MY18 Skoda RS169 Wagon w/ Tech & Lux, 2007 VW MKV Golf GTi
    Quote Originally Posted by Pawnii View Post
    RCD310 is already on Parts for Sale - listed here http://www.vwwatercooled.org.au/foru...ode-75991.html
    If I can't get the dealer fitted bluetooth unit working this will end up in the parts for sale section as well (once I get a 9w7).
    The reason I think it is a dealer fitted unit is that they've just dumped the bluetooth unit on top of the a/c controls - not where a factory installed unit would be I'd think.
    Quote Originally Posted by 99_FGT View Post
    Al..
    Nope - no telephone option under the settings menu. My question is whether this option needs to be enabled in VCDS or if this is a function of the bluetooth module and the RCD510 recognises it and adds this as a menu.
    I'm guessing it needs to be supported in hardware (9w7) and enabled in software (VCDS). But I'm only guessing.
    I just want to be sure that my bluetooth (Novero HT-3 / 1K8 051 730 D) isn't going to support phone book (as it does streaming audio)
    Adelaide hills, SA
    The BT was most likely not factory fitted. It could be worthwhile to check the coding in vcds, before you buy a 9w7.
    Yes that's what I was figuring - the dealer charged full price for bluetooth and put in a "cheapie".
    It's at least worth hooking up to with VCDS to see if the functionality can be enabled. If I didn't have to spend $300 on 9w7 and then mess around fitting it that would be good.
    Adelaide hills, SA
    It's not that hard to fit it.
    + you will always get something for the old BT when you sell it. If it comes to it.
    Yeah I know. I've already had the stereo out twice - once to fit the RCD510 and second time to locate the bluetooth unit
    It's just a bit of a messing around to install the microphone (if I change over cabling too).
    Mackay QLD
    Hi Tigger
    I have just bought another RCD 510 and tested it in my Tiguan last week to check the pin supplied was correct and to test the RVC connection as I am planning to purchase another Tiguan soon. I think you will need to get access to a VCDS cable as you need to code the unit to your Bluetooth module just like I had to do with the RVC . I did see a byte/bit to toggle on and off in the radio module unfortunately I do not have a Bluetooth module to validate your issue. The fact that you do not have the telephone option in the setup menu in the RCD 510 implies that the unit has not been coded to recognize the BT module.
    I have noticed some mobile phones do not transfer via BT their phone book details on my SIM card or phone memory to my audio unit in my BMW. Have you tried another mobile brand Nokia iPhone? just a thought!
    Do you have a copy of the RCD 510 manual? I had a quick glance at mine and it appears there are number of steps to be done to get the phone book into the radio unit's memory.
