Results 1 to 10 of 62
Thread: RCD330+ OEM Camera connection
    Sep 2014
    Mine was done with a flip badge camera.
    Sent from my SM-G955F using Tapatalk
    Jun 2012
    Quote Originally Posted by ZantetsukenJ View Post
    Oh wow. Ok so to check the parameters of your install:
    - OEM low line RVC camera - flip badge model (RGB output) [does anyone know if theres any difference in the ones installed on the passat on those on the Golfmk6?]
    - RCD330 plus
    - RGB to CVBS converter from Ali express - Something like this?
    HTML Code:
    https://www.aliexpress.com/item/Hot-RGB-to-AV-CVBS-Signal-Converter-Adapter-Box-for-OEM-Factory-Rearview-Backup-Camera-for/32749913857.html
    - Adaptor for RCA to Blue plug (presumably the ones that get "gifted" with the rcd330?) - I.e. this? -
    HTML Code:
    https://www.aliexpress.com/item/Crngiar-Car-RVC-Cable-Adaptor-For-Volkswagen-Golf-VI-Jetta-5-6-MK5-MK6-Passat-B6/32834691932.html
    Photos of the various adaptors would be greatly appreciated if possible - i've spent forever trying to research what is in the art of the possible with my car.
