Page 4 of 7 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 62
Thread: RCD330+ OEM Camera connection
  1. #31
    Apr 2018
    Frenchs Forest, Sydney
    I finally got my RVC working on my GTI MK6. Ended up being a dodgy adaptor, but also got told by another member to try the reverse wire from the plug for the RCD510. Lo and behold it worked.
    @ZantetsukenJ, thats unreal, well done!! Can you please clarify which converter you used, perhaps send a link to it? I am trying to connect OEM Lowline RVC (Handle type in Passat Wagon), into a RCD330... do you think I should (hopefully) see similar success? I dont have or need the moving reverse lines, just the static ones.
  2. #32
    Apr 2018
    Quote Originally Posted by ZantetsukenJ View Post
    Sent from my SM-G955F using Tapatalk
  3. #33
    Sep 2014
    Quote Originally Posted by ak7723 View Post
    Absolutely, I don't have the moving reverse lines either, I just have static ones which I think indicates mine is also a low line camera. I don't have a link unfortunately as I bought it last year off alibaba. You just need a converter with a reverse, positive and negative line and a video line either going to the blue plug or RCA and then an adaptor going from RCA to the blue plug.
  4. #34
    Apr 2018
    Great. And I presume you didn't need a delay timer?
    And can you clarify what you connected the reverse wire to?
  5. #35
    Sep 2014
    No delay timer at all!
    The cable I connected to was the yellow cable on the blue plug that's off the harness
  6. #36
    Sep 2014
    This is the one I used for the reverse wire.
  7. #37
    Jun 2012
    Has anyone had success with an OEM flip badge camera? Does it make a difference compared to the handle type?
  8. #38
    Sep 2014
    Mine was done with a flip badge camera.
  9. #39
    Jun 2012
    Oh wow. Ok so to check the parameters of your install:
    - OEM low line RVC camera - flip badge model (RGB output) [does anyone know if theres any difference in the ones installed on the passat on those on the Golfmk6?]
    - RCD330 plus
    - RGB to CVBS converter from Ali express - Something like this?
    HTML Code:
    https://www.aliexpress.com/item/Hot-RGB-to-AV-CVBS-Signal-Converter-Adapter-Box-for-OEM-Factory-Rearview-Backup-Camera-for/32749913857.html
    - Adaptor for RCA to Blue plug (presumably the ones that get "gifted" with the rcd330?) - I.e. this? -
    HTML Code:
    https://www.aliexpress.com/item/Crngiar-Car-RVC-Cable-Adaptor-For-Volkswagen-Golf-VI-Jetta-5-6-MK5-MK6-Passat-B6/32834691932.html
    Photos of the various adaptors would be greatly appreciated if possible - i've spent forever trying to research what is in the art of the possible with my car.
  10. #40
    Why use an adapter if you don't need to?
    You can get flip badge cameras that are composite video out.
