Hi everyone, FYI I received a RGB to AV converter from AliExpress yesterday and connected it all up and it now works! To clarify, here are the parameters:
VW Passat 2011 B7 Wagon
VW OEM RVC Handle Type (retro fitted)
RCD340 (should be same for RCD330, I chose 340 so I have CarPlay and Android for better resale)
Here us the converter I bought
26 PIN RGB to CVBS (RCA) AV Converter for Volkswagen Factory Original Camera Output to After Market Head Unit DVD-in Vehicle Camera from Automobiles & Motorcycles on Aliexpress.com | Alibaba Group
However I told the seller what camera I had and he sent me more suited version for my car/camera (in his opinion).
At first it did not work.
I connected the yellow wire to 12v+ and the black wire to Earth. However I left the red wire labelled "Back" connected to nothing... and nothing happened, however in the end after some google searches I tried connecting the red wire to the 12v+ as well and to my amazement it all works now!
Picture appears pretty quickly once reverse gear is selected, however picture quality is not great! Firstly the image quality is darkish and blotchy. Secondly, the field of view is pointed more downwards, and possibly even wider as I see more bumper bar and less sky than previous, which baffles me as I have not changed the camera or touched it. When it used to be connected to a RNS510, the field of view was better and the image quality was clearer.
So after all this im probably going to try/buy an after market camera to see if I can improve quality. I initially avoided this option because it was so hard to retro fit my OEM camera, I did not want to go down that road again replacing it (getting the wires through the boot grommets was like pushing an elephant through a straw). Im hoping I can just cut and solder the wires of a new camera in the boot, and use the existing wires to carry the data to the head unit...
Anyway, just wanted to share my experience. Yes OEM RVC works with converter, however quality is not as good as I expected.
