Results 1 to 2 of 2
Thread: RCD310 install into 2005 golf gti mkv
    Apr 2011
    Hi guys
    have tried installing an rcd310 unit into the golf gti mkv.... havnt updated the canbus yet.
    however, without coding the unit ( have to find someone with vagcom yet )
    switched on the unit , it was displaying "1000" Safe... i then proceeded to put in the security code
    and all the unit does now is say "SAFE" in big letters.. yet when i click the cd button it will start playing a cd....
    it gets interesting....
    once i switch off the car. it now goes back into this "SAFE" screen and from then on i cant access any function, unless i manually unplug the unit from the rear...
    does this mean i have a bogus unit, bogus code (which was supplied by vw so it shouldnt be wrong) or is it a simple matter of coding. the unit in it previously is a mfd2 sat nav.
    doing all these trials before i fit my rcd510 in and coding occurs!
    appreciate your views.
    i apologise in advance if there is the same thread open somewhere but i havnt found any .....
    cheers !
    Apr 2011
    BUMP * someone surely must know what im on about ... please?
