Results 1 to 6 of 6
Thread: RCD 510 in MY07 MkV
    Eden Park
    RCD 510 in MY07 MkV
    Hey guys
    Just recently acquired an rcd 510 to upgrade from an rcd 300 unit in my golf.
    Ive been told it is a straight swap, if so, fantastic. Youtube videos show the install to be quite simple.
    However i have been told the coding is a pain in the neck, i have the code for the 510... But ive been informed i need to code it (pair) with my car to work, especially with the steering wheel controls
    If anyone can shed a light on this, i can install this asap, as im over using mp3 cds.
    Whilst im at this, how much is a mdi kit for this unit? I would be using an iphone obviously but i highly prefer an aux input.
    Btw i have searched on this with little satisfaction as most people have rns systems and i have no interest in sat nav
    Regards
    Matt
    I am here: http://maps.google.com/maps?ll=-37.492882,145.070269
    Jul 2010
    Robina Gold Coast
    It could be a straight swap and every thing might work ,if the RCD 300 steering wheel controls worked before it should be a straight swap ,
    Eden Park
    Everything works, i juss get told by my friend who had a R32, he upgraded to an rcd or rns from his 300., that the car needs coding to the radio vice versa...
    If someone has done this conversion with out intervention from vw, please say so
    I am here: http://maps.google.com/maps?ll=-37.492876,145.070336
    Mindarie, Perth (WA)
    The RNS510 requires some VCDS coding (to enable the MFD display etc)....but, AFAIK the RCD510 is a straight plug n play.
    Eden Park
    Guess ill have to have a go and see what happens ey
    Ill advise on results when the weather cools down for me to change it over, little warm in melb at present
    I am here: http://maps.google.com/maps?ll=-37.492887,145.070467
    Eden Park
    Installed the unit yesterday on my own and works a treat!
    how ever, i looked and was curious as to if i can manually wire up and AUX in, pins are there, so it should work by rule of thumb
    anyone attempted this?
    Matt
