Fitting an RCD-510 is a piece of cake to install! Pretty much plug and play
It was the first thing I did when I bought my Passat a couple of years ago, but I have upgraded again to the RNS-510 since then.
I have wanted install the Bluetooth kit myself, but I can't really justify it. I have installed the Media Device Interface into the glovebox and I don't use my phone much while driving. I reckon the worst part would be routing the wiring down to under the seat (presuming you were planning on installing it there). And of course, it won't work until it is coded in. Hopefully someone in Hobart can help you there, I have a VCDS cable but I'm not down your way much.
Also, I think that USB/Aux plug you have pictured there is for the Chinese model RCD-510's, you would probably need a Media Device Interface for your unit. There are two different types you see. I'm not 100% sure though...
2017 VW Tiguan 140TDI Highline
2012 VW Touareg V6 TDI
1985 Mercedes-Benz 380SE
