That's dissapointing =(
Is that the original amp for that system? If not, you may also have impedence issues that may affect your amp.
If they are the right speakers, I'd be looking for a better amp. Also, the 'Dynaudio' (typically Lear) amp from the Passat is supposed to be specifically tuned for that cabin...
Unfortunately, the Passat amp is not cheap to buy aftermarket..
