Front door trim removal is very similar to the rear door trim removal, except for the driver's side door (detailed below), the number of wiring connectors to unplug, and there being two T20 Torx screws on the bottom of the trim on each door (pictured below).
Tip: If you happen to snap off any Christmas-tree clips, they can be re-attached using a smothering of epoxy resin (ie. Araldite) - I only broke two during the whole install, which is good for me (thanks to the plastic door trim removal tool)
Steps:
The driver and passenger doors have different handle structures and therefore require slightly different steps to remove. Otherwise trim removal for each door is very similar to the rear doors.
Driver-side Door Trim Removal:
1. Using the door trim removal tool, gently remove the driver-side door control unit (with electric windows, mirrors etc).
2. Unplug the master electric window switch and the electric mirror switches and put the control unit aside.
Apologies for photo quality, by this stage in the project I was racing against (dinner) time and taking less photos to choose from.
3. Remove 3x T30 Torx screws in the handle.
4. Remove 2x T20 Torx screws in the bottom of the door (pictured below). I nearly missed the second one - seems I learnt from the first door.
5. Gently pry the trim off the door frame (using trim removal tool that has the hammer-like claw). Locate the Christmas tree clips as pictured in the photo below and use the claw tool to unlatch these - push it between the two parts of the clip and it will easily disengage. There is one really tricky clip, around 1/4 the way from the top, under the tweeter - it's a far way in and inside a cavity in the door frame... I broke this one on both doors (all other clips remained intact). do not pull the trim from the frame yet, it is still attached by wires/cables
6. You may need to gently lift the trim to disengage it from the window ?clip - do not pull the trim from the frame yet, it is still attached by wires/cables
7. Whilst juggling the door frame (less profanities required on this door), unclip the control unit plug (on the door frame itself) by opening the pink lever. There is no tweeter plug to remove on this trim.
8. Unclip the door lever cable by first unhooking the cable from the latch. I discovered it was much easier to unclip the hook while lifting the door lever (ie. 'opening the door'). Once it is unhooked, there is a plastic clip to unclip. The cable should then easily come off.
9. The door trim should now come off (be gently in case it's still attached somewhere). Put it aside on a soft surface (like in your trunk/boot) - once again, not on concrete/pavers like I did with the first door
Passenger-side Door Trim Removal
The passenger side door trim removal procedure is identical to the driver-side, except for the handle design (which is the same as the rear doors), and for the need to unclip the power window plug rather than the two control unit plugs (mirrors & master window controls).
BTW - I found on this door it was easier to unplug the electric window before unclipping the trim.
It also has the tricky Christmas-tree clip that I managed to break even though I knew to look for it
Here's a photo of the handle with the cover removed:
