Results 1 to 10 of 13
Thread: R32 MKV 2008 stock/OEM sound system?
    Mar 2008
    NSW
    Just wondering exactly what the stock/oem 2008 R32 MKV sound system consist of? Was there a sound system upgrade or just the one stock? 3-ways up front and 2-ways for rear? Is there an amp or just powered from the HU?
    Also just installed my RNS-510 which works however there is no fader option no sure if this is anything to do with detecting an amp etc...
    Apr 2009
    Hobart
    AFAIK, there is no amp. The "premium" sound that the GTI and R32 boast just consist of 10 speakers rather than 8. The stock HU is just the RCD500.
    2009 .:R32 5Door Black Magic DSG Sunroof Stubby Antenna
    2007 Honda CBR1000RR Fireblade Yoshimura RS5 Carbon Fibre Pipe
    Jan 2008
    R32 and GTI have an amp under the passenger seat unless you purchased Sat Nav with the car. You get 10 speakers and the crossovers are built into the amp.
    The RNS 510 needs to be coded to the car to tell it that it has a soundsystem installed, once this is done you'll get the fader.
    Mar 2008
    NSW
    Thanks, how do I code my RNS-510 for this setting? Can it be done easily with the new firmware?
    Also how easy is it to replace the stock amp with an aftermarket swapout?
    Sep 2009
    Stretton, QLD
    I had the rns-510 installed as a dealer fit option on delivery, does that mean I still have the factory amp under the passenger seat but its being bypassed? And also, I don't have the fader option, howcome?
    Jan 2008
    Quote Originally Posted by silver32 View Post
    You have the factory amp and it will be working however your RNS 510 hasn't been coded correctly hence the lack of the fader option and your sound quality won't be up to scratch.
    Jan 2008
    Quote Originally Posted by airofu View Post
    You'll need a Vagcom/VCDS or a dealer tool.
    Not so easy as the crossovers are built into the amp. Depends on what you want, see how the stock unit goes when it's setup correctly.
    Sep 2009
    Stretton, QLD
    Does anyone have a Vagcom and can code it for me? I'm in the stretton/calamvale area in Brisbane....
    Mar 2008
    NSW
    Would be interested also in Sydney
    Feb 2009
    I have one. I'm at The Gap - either Thursday evening or next week sometime. Maverick, what needs to be coded?
