Originally Posted by
Celestine
Have you considered using the boot of the car? Just have them implanted side on (not preferable for SQ though) in a sealed/ported fibreglass box? Wont be cheap to do but definately seen it being done before.
Under the seat's another suggestion. I myself at once stage was thinking whether or not to build a sub box small enough to bit into my pull out draw/seat height adjustment section. However, ensure that there is enough room for the sub to clear during it's maximum extrusion. If not, you'll obviously damaged your sub. You'd be looking at a 8" that requires very minimal box size. So you're looking at the likes of an ID 8" or a Hertz HSK8". If memory doesnt serve me wrongly, the Hertz HSK 8" only requires some ridiculous amount like 5L.
*Edit
found it - it's 7L's for a sealed box.
http://www.hertzaudiovideo.com/Doc/pdf_hx200.pdf
Great idea Celestine,
but that is a no go even with the seats at it fullest height you aint gona fit a sub under there. Heck you would be hard pressed to install one under the mk4 seats.
Audi S4 (2001) - Imola Yellow
Secret Project
