Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Project: Sub box for The_Hawk
    It was only a test fit..
    It's all complete.
    Here is the run down of the box:
    The back wall
    The wall is layered with 4 coats of 400G choped strand of fibre glass.
    Skeleton
    2 inverted L shaped 18mm ply wood and 12" ring.
    Base
    MDF base with 4 layer for 400G fibreglass.
    Surface
    Cotton material with resin with another 4 layers 400G fibreglass.
    Stablity
    The tight fitting of the fibreglass mould is aready very stable but it is also reinforced with anti slip mats on the base.
    Terminals
    It is secured inplace with silicone and glassed over to prevent air leaks.
    Volume
    The bubble test shows ~24-26L.
    Carpeting
    not the best "carpeter" Still needs a little more attention
    I would recommend a $30 worth of dynamat / a 12'' subwoofer gasket on mounting point to stop air leads. By doing so the bass will be more solid, Otherwise it sounds great and works fine.
    Enjoy Your boot space again Aaron.
    Jul 2007
    Bondi
    haha. My bad.
    Came up good.
    Dec 2006
    Kilsyth, VIC
    I think I just messed myself a little
    Very nice work Louis. I tell you I really am missing the bass end of the sound ...
    PM coming your way!
